Rubber Spacers
Old Mar 4, 2008 | 09:08 AM
Ogre's Avatar
Ogre
Default RE: Rubber Spacers
Where did you get the headers that are on your car? They are so low, they look like headers that are for a truck with a 302. My long tubes aren't near that low.
Old Mar 4, 2008 | 09:16 AM
cprstreetmachines's Avatar
cprstreetmachines
You need to learn how to go over speed bumps.
either go over at an angle or gas it a bit to lift the car over the bump then slow down!
Old Mar 4, 2008 | 09:24 AM
kalli's Avatar
kalli
i had the same problem. header about same height and at every speedbump i would scrape on the ground.
my front was a bit lower though. you can always try that method with those thingies (i don't knwo them).
I got a proper set of heavy duty springs and shocks and my problemm was gone since.
so maybe check on your shocks (that;s easily done). if they're fried they'll allow the car to swing that low.
if you have an I6 to V8 conversion you might need different springs in the front
Kalli
jc409
Convertible Tech
Sep 24, 2015 03:38 PM
stark777
Sep 21, 2015 12:46 PM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
Webster454
Sep 7, 2015 04:59 AM
