Heater Box Removal
Old Mar 6, 2008 | 01:04 PM
dgoldwasser's Avatar
dgoldwasser
Default Heater Box Removal
I've posted similar issues before, but now an update question. I'm having "issues" with the two hoses to the heater box. I've loosened the clamps but the the hoses are locked onto the heater. Short of cutting them off, how can I get them off? I need to remove the hoses to get at the bolts holding the heater box to the firewall.
Any thoughts? Would a heat gun work to loosen them up? (Provided I had a heat gun.) I've got to imagine that there is a easier way to get them off. Thanks.
Dr. Rustecomy
[/align]
Old Mar 6, 2008 | 02:15 PM
Adrenolin's Avatar
Adrenolin
Default RE: Heater Box Removal
If they are original hoses I'd cut and replace them. Depending on their shape you may want to do that anyways. That said, if you are going to reuse them then start pulling hard! I've used a heatgun before and its helped sometimes and sometimes not.
Old Mar 6, 2008 | 03:18 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Now is the time to replace the hoses. Try using channel locks and gripping the hose and twisting, that might help. Also, the only bolts that hold the box to the fire wall you can get to from the engine compartment. They are around the heater blower motor.
Old Mar 6, 2008 | 03:29 PM
TexasAxMan's Avatar
TexasAxMan
Cut a small slit (about an inch) in the hose (parallel to its length) then peel it off the heater core. You may have enough length left to reconnect. But, if they are very old, replacing them is very cheap.
Old Mar 6, 2008 | 07:11 PM
baddog671's Avatar
baddog671
Big pair of channel locks...
There are4 nuts that need to be removed in the engine bay, and 1 screw under the dash, and it should come out...atleast on my 67.
Old Mar 6, 2008 | 11:13 PM
Gun Jam's Avatar
Gun Jam
On my 66 I would remove the hoses from the engine and then just pull them out with the box I dont remember then blocking access to any fasteners. The 4 on the firewall and then one down by the dash I think.
-Gun
Old Mar 7, 2008 | 09:05 AM
rbrown22's Avatar
rbrown22
replace them.... Now is the time..I would just cut them off outside the firewall on the engine side.... then let them drain a little....
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
Dathan
Oct 5, 2015 05:52 AM
