distributor wire question
Old Mar 13, 2008 | 09:36 PM
jamieNerikas66stang's Avatar
jamieNerikas66stang
Default distributor wire question
two wires coming out of distributor,...black goes to negative on coil, red goes to postive on coil? correct,..sorry for dumb question,...
so postive side of coil will have two wires connected to it? i have another wire connected to it from the wire harness,? correct?...
Old Mar 13, 2008 | 11:09 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: distributor wire question
sounds like you have a petronix ignitor kit installed in your dizzy to eliminate the points black wire to neg coil..red to pos coil and the second wire on the coil is switched 12 volt ignition.. = correct
http://www.pertronix.com/support/man...itor12vneg.pdf
Old Mar 13, 2008 | 11:10 PM
ky's Avatar
ky
America ftw
MSD is way better than petronix. done.
Old Mar 13, 2008 | 11:13 PM
mjr46's Avatar
mjr46
true... but he has what he has and must make use of it.. I have msd..but at one time I did have petronix
Old Mar 15, 2008 | 04:50 PM
jamieNerikas66stang
sorry its a procomp dizzy,...
Old Mar 15, 2008 | 05:10 PM
kalli's Avatar
kalli
positive side of coil should have a wire coming from ignition switch
it should have 7.5V+ or 12V+ when ignition is on (depending if you have a resistor in your wire or not)
From here the distributor should get + for it's module as well.
So from this it does sound correct. Is it a new install?
any problems?
Old Mar 15, 2008 | 05:27 PM
jamieNerikas66stang
yes, everything in the engine bay is new, completely new install from bolts to block to wires, and i remember the old stock dizzy only having one wire that i think went to the negative on the coil and the wire from ignition went to +, but now i have two wires on positive and one on negative,...its a procomp dizzy with magnetic pickups, no more points for this pony
2007StangV6
Jan 28, 2016 06:09 PM
StalkerGT
Sep 25, 2015 02:41 PM
04stangman
Sep 17, 2015 01:45 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
