Clutch Adjustment
Old Mar 17, 2008 | 11:21 AM
6t9 stang's Avatar
6t9 stang
Default Clutch Adjustment
I just finished my T5 swap and adjusted the clutch the other day. In order to disengage the clutch I have to tighten the cable until the clutch pedal is 4 INCHES above the brake pedal... It also doesnt disengage until the pedal is almost at the floor..This cant be right,Is there some sort of pedal stop that an automatic car would be missing.
also will the diaphragm loosen up over time.
Old Mar 17, 2008 | 12:45 PM
gjz30075's Avatar
gjz30075
Default RE: Clutch Adjustment
No, certainly not right. There's got to be lost motion somewhere. Have someone watch the movement of the fork while pushing the pedal. Should be almost instantaneous. If not, maybe the fork is cracked, or the cable is not moving ina linear way.
Old Mar 17, 2008 | 12:51 PM
67mustang302's Avatar
67mustang302
What clutch are you using? And are you certain it is now adjusted properly, ie it engages/disengages properly?
Old Mar 17, 2008 | 01:09 PM
6t9 stang's Avatar
6t9 stang
The clutch is A superior ( Came with Modern Driveline Kit). As far as adjustment, I tightened it just enough to allow it to disengage when I depress the clutch pedal
Old Mar 17, 2008 | 01:43 PM
6t9 stang's Avatar
6t9 stang
Thats what I dont get, when the pedal was set at the correct height, I watched the clutch fork and it DID immediately begin applying pressure to the pressure plate, however it wouldnt disengage the clutch.
Old Mar 17, 2008 | 01:50 PM
gjz30075's Avatar
gjz30075
Possible that the disc is in backwards?
Old Mar 17, 2008 | 03:22 PM
6t9 stang's Avatar
6t9 stang
No, I was extremely careful putting it in
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
junior04
Sep 28, 2015 10:53 AM
