T-5 Here I Come!!!
Old Mar 17, 2008 | 07:34 PM
PReal's Avatar
PReal
Default T-5 Here I Come!!!
Just got off the phone with a guy from a local mustang forum.
Tomorrow night I'm heading into town and picking up a T-5 from a 91 mustang everything from the blockplate/flywheel back for $450.
The car only had 90k and was running great when he pulled the motor and tranny.
I'm pumped!!!
AHHHHHHHH!!!
Old Mar 17, 2008 | 07:56 PM
JamesW's Avatar
JamesW
Default RE: T-5 Here I Come!!!
Great catch. Everything there makes a big difference. Now comes the questions:
- What to do about flywheel
- What clutch to use
- How to mount rear crossmember
- cable or hydraulic clutch
- driveshaft length
- Shifter selection/install
Old Mar 18, 2008 | 12:22 AM
gothand's Avatar
gothand
What engine do you have? The flywheel you're getting is a 50 oz. imbalance if it is original to the '90 and if you have an early model, it is likely a 28 oz. Make sure to use the correct one for your application.
Old Mar 19, 2008 | 05:33 PM
PReal's Avatar
PReal
I ended up not getting the flywheel or block plate.
I'm buying a flywheel of ebay.
Using Cable Clutch.
Buying a used crossmember for a 64-66 with a T5.
Buy the block plate from a local shop.
I'll use the stock shifter for now and if its too short (I'm 6'4" though) I'll buy one that is more correct.
Old Mar 19, 2008 | 09:03 PM
Scott H.'s Avatar
Scott H.
Old Mar 19, 2008 | 10:11 PM
flyingfool's Avatar
flyingfool
this swap has been gettting more and more popular on here!
Old Mar 19, 2008 | 10:28 PM
Daze's Avatar
Daze
ORIGINAL: flyingfool
Did you ever get your T5 back together???
settled4automatic
Sep 24, 2004 10:51 PM
settled4automatic
Sep 22, 2004 03:59 AM
mcgyver8062
Dec 31, 2003 08:56 PM
smithSHO
Dec 12, 2003 03:10 PM
DougBlevins
Mar 24, 2003 03:42 PM
