i took out my engine today :(
No, you need a T5 bellhousing for a cable arrangement. I'm not that familiar with a 5 bolt block/bellhousing. Will a later 4 speed bellhousing ( or a T5 bell) even bolt up to a 5 bolt engine? And just be missing a bolt? Or is the bolt pattern completely different?
ORIGINAL: PONYBOY65
can i use the cable clutch set up with an early bell housing?
This will require some welding, but it is a fairly simple procedure... Check out the MustangSteve website out really well... this conversion process is in there somewhere.
<< http://www.mustangsteve.com/scattershield.html
Ok, I reviewed the website and while there are not directions there for a bell housing, there are directions for a scatter-shield. I am of the opinion that the directions could apply equally for a stock housing except that welding probably should not be done, but drill and tap should work fine in conjunction with an adjustable ball pivot.
http://store.summitracing.com/partde...p;autoview=sku
In other words, if you really want it to work, you will need to plan it out well, but it won't be really difficult or expensive.
You are in a pickle. The 5 bolt bell housinguses 5 bolts to secure it to the engine so a 6 will not work. It also uses a different bolt pattern to bolt up the transmission. The adapter plates I have seen will only work with the 6 bolt bell housing due to the different transmission bolt pattern. Start by confirming that you have a 5 bolt bell housing. How many bolts secure the bell housing to the block? For those that are wondering you can use a cable clutch with an early style 6 bolt bell housing. You have to get the pivot/fulcrum that mounts inside the passengers side of the bell housing and eliminate the stock fork pivot on the drivers side.
I'm not sure if you can use the 5 bolt bell housing and put a T5 behind it. If you can get that to work you can use a cable clutch. Just change the fulcrum pivot point just like a 6 bolt bell housing. Did you figure out for sure if it was 5 bolt or 6 bolt?
TfcCDR
Sep 14, 2015 12:08 PM
