Heater core help??
Old Mar 20, 2008 | 08:43 PM
quinchem's Avatar
quinchem
Default Heater core help??
I'm about to replace my heater core...got a nice green stream running along my passanger floor. I've bypassed it for now but being a convertable I want heat. Can someone give me a crash course on the job?
Thanx
Old Mar 20, 2008 | 09:19 PM
ninteen66mustang's Avatar
ninteen66mustang
Default RE: Heater core help??
I think you have a 68, judging by your other posts, so it may vary from my 66.
There are a bunch of clips I had to take off around the heater box, and maybe a bolt? (i did this a while ago). After the front was off you could see the heater core. I removed the hoses from the engine and the with lots of coaxing, got the heater core out. I replaced the whole heater box and the foam and rubber seals at the same time (I actually didnt replace my core, but cleaned it and stuff). I got new hoses, cut them to the correct length, and put them back on the core. After that I pretty much worked backwards.
Let me know if you have any questions.
Old Mar 20, 2008 | 09:24 PM
quinchem's Avatar
quinchem
Thanx for the reply and yes I do have 68. Is this a standing on your head under dash job?
Old Mar 20, 2008 | 09:35 PM
ThanksDad's Avatar
ThanksDad
http://www.mustangmonthly.com/howto/5769/index.html
This is for a 66, I would assume yours is similiar.
Old Mar 21, 2008 | 09:01 AM
quinchem's Avatar
quinchem
Thank-you...this is perfect!
Old Mar 21, 2008 | 09:31 AM
65poppy's Avatar
65poppy
Hi. I did this job on a 65 Mustang. It isn't too bad. Getting hte plenum out of from under the dash, and then back under that dash and all hooked up is the hardest part. So yeah, you're gonna be on your head for a while. I hope you have skinny fingers.
Old Mar 21, 2008 | 03:55 PM
ninteen66mustang
If you want, it will prolly help to take out your passenger seat. Its not that hard and will give you more room.
Old Mar 23, 2008 | 05:30 PM
mightythor99's Avatar
mightythor99
i did it upside down,.........when i used to be able to bend that way. it was easiest upside down,.........legs going up in the air. noadays, i'd say it would be easier, to pull the whole thing, and so it that way. wasnt that smart when i was younger i guess..........was more of a challenge upside down!
djbigskrilla
Sep 20, 2022 01:04 AM
mrtrodonet
Sep 19, 2020 03:12 PM
Seanam
Oct 4, 2015 10:15 AM
Calizic
Aug 28, 2015 01:46 PM
Mnuckolls
Aug 9, 2015 08:54 AM
