how screwed am i
honestly, the one thing that i learned is that if your gonna spend the money you might as well spend it on the best stuff, even though it might be more expensive. I would go with something like the afr 165 heads. They are awesome heads and will really bring the motor to life especially if you put in a bigger cam.
yeah but i cant see spending that much to raise the hp on a car that gets driven maybe 500 miles a year
so just to make sure i read all this correct,
for the gt40 heads i need the heads off of a 95-96 explorer with 2 casting marks and 1.7 rocker arms.
anything else?
anything else?
yeah they have three casting marks and they are from 96-97 i believe the casting number starts with f3 for 93 and also gt will be cast on near the lower head bolts
update
both heads are off.
the a/c and p/s brackets are a pita but no more debris in the heads.
a quick run to the machine shop to get them cleaned and a valve job and they go back together
both heads are off.
jwog666
Dec 27, 2021 08:09 PM
breaking
Oct 2, 2015 01:27 PM
