2 stroke or not 2
Old Mar 31, 2008 | 10:51 PM
firestang66's Avatar
firestang66
Default 2 stroke or not 2
Well since this is my first headlong leap into restoration I have quickly learned the value of information, and have got good and bad from many sites. Now I have a small issue to work out, and could use some moterheads advice.
My issue stems from-- A: not having an engine for my 66 coupe. B: having a friend give me a rebuilt 351W with electronic fuel injection with about 80 hours run timeit, this was out of a 87 F150. It needs work because it has oil in the coolant, but thats a different topic.
I would love to stroke this moter out to a 408, and keep the fuel injection. Is this 2 much HP?, and would any of the Ford injection parts be of any use? I live inColorado and going up the hill takes youtoo 11-13k feet. This really makes a carburated engine a pig with no power, buta computer controlled ignition adjusts to the elevation and runs optimal. The big stroked engines I see in magazines and on the net all seem carburated.Should I not stroke it and be happy with the power of the factory 351W?
66 coupe, toploader, 351W, 8"/280, being "derusted" on the rotisserie
Old Mar 31, 2008 | 11:04 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: 2 stroke or not 2
if you stroke it to a 408...that f-150 craptastic efi will definately be of no use... a mustang efi set up is what you need..but if you put all that power of a 408 down in your chasis..you'll need the suspension/drivetrain for it and any and all supporting mods..it'll end up being a mushroom...on the other hand the 351 with a mild build and you won't have to get to wild with all the other stuff..and carb will be a much quicker route to go
Old Mar 31, 2008 | 11:53 PM
flyingfool's Avatar
flyingfool
^ +1 on that....stroking is pretty much replacing half the motor too. i dont know about your $$ situation, but a built 351 is deffinatly cheaper AND easier
Old Apr 1, 2008 | 12:51 AM
67mustang302's Avatar
67mustang302
A well built 351 with roller cam, good heads, intake, supporting mods and a nice carb, will still be faster than most other cars on the street. It'll still require some suspension and drivetrain assistance though, but nothing radical.
drfister
May 3, 2018 10:38 PM
1987gt40ttopt
Aug 28, 2015 10:49 PM
SCARFACE
Chop Shop
26
Jun 30, 2006 03:04 AM
mysticsvtcobra96
Jan 8, 2005 11:48 AM
18
Oct 27, 2004 02:17 AM
