Preceived tire width
Old Apr 17, 2008 | 11:20 AM
hammerit's Avatar
hammerit
Default Preceived tire width
I have 215/70/15 tires and they are a bit narrow for my taste. I've seen 215/60/15 tires on other cars and they seem considerably wider. Is it just an illusion or is it a differance between the 70 series and 60 series or does wheel width make any differance. Thanks
Old Apr 17, 2008 | 11:33 AM
Norm Peterson's Avatar
Norm Peterson
Default RE: Preceived tire width
Probably a little of both. The "squattier" 60 series will tend to look wider because of its proportions. And tire section width varies with wheel width, by about 40% of the change in wheel width. IOW, if you have a tire that truly does measure 215mm (8.46") on 6.5" wide wheels, it would measure 8.86" wide (or 225mm) if mounted on 7.5" wide wheels instead.
So if the 215/70's are on 6" or maybe 6.5" and the 215/60's are on 7" or 7.5" . . .
Norm
Old Apr 17, 2008 | 11:34 AM
crunchyskippy's Avatar
crunchyskippy
Comparing the two sizes you mentioned, the width would both be ~8.5". The only variable (60 vs 70) represents the percentage of the sidewall as compared to the width. And since we're only talking 10% difference, the 70 tire would be about ~.84" (rounding)taller, as in the wheel diameter would be just about 3/4" taller for the 70.
The difference in width you are probably noticing has more todo with the rim width. How wide are your 15" Magnums...I'm guessing 7"? Maybe the comparison had 8" wheels. Also, tread pattern can sometimes play an optical allusion with regards to perceived width (at least to me).
So in short, you should focus on the first number for width. But keep in mind that the second number will change by default, since it is a percentage of the first.
---EDIT--- Norm beat me to it, but the idea is the same!
Old Apr 17, 2008 | 11:58 AM
kalli's Avatar
kalli
you're tyres look fab from the side.
love em.
Old Apr 17, 2008 | 03:16 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Tire Rack has a lot of tire information.
TIRE TECH
Old Apr 17, 2008 | 09:19 PM
hammerit's Avatar
hammerit
Thanks all, at least I kown i'm not just seeing things
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
