Getting an old 66 running again
Old Apr 23, 2008 | 09:03 PM
9tyfiveo's Avatar
9tyfiveo
Default Getting an old 66 running again
Okay, so I have an old 66 original 289 sitting out in the yard i'd like to get running again. I don't know much about the older ones even though it seems their simpler. haha So this iswhy I'm here since I have no friends to help me out, (they all left for college!). I was hoping you guys could help me. I just bought a new battery for it today. All the lights and such turn on inside and out, so electrical is hooked upI believe correctly. It turns over but won't even attempt to start. Idumped a little gas in the carb, and some in the tank, still nothing.so that's as far as I am. Any help would be great! thanks!
and help me get it running and ill give you $10 via paypal : )
Old Apr 23, 2008 | 09:12 PM
66JameStang's Avatar
66JameStang
Default RE: Getting an old 66 running again
Doesn't look too too bad... Was it running when it was put out to sit and how long has it been sitting.... If it has been sitting along time and you live somewhere it freezes I would drain your water to make sure it had antifreeze in it... and then refill and check for leaks... second drain the oil and refill and check for leaks... If the carberator is sitting with open valves or there is place for dirt to gain entry you are gonna wanna remove components such as the manifold and start cleaning the heads and all.... of course this is all speculative!
Hope this helps a bit
Old Apr 23, 2008 | 09:26 PM
9tyfiveo's Avatar
9tyfiveo
I checked the antifreeze, full. and oil, full, and not too dark. (edit)No, the carb was covered, the filter's taken off in the picture for when I was trying to get it running, was clean and clear(/edit) I just would like to see about getting it to huff and puff before I spend the money for oil for a car i might have to pull the motor from. lol and how much is antifreeze now? $15 a gallon or something crazy?
Thanks.
Any other suggestions?
Old Apr 23, 2008 | 09:31 PM
9tyfiveo's Avatar
9tyfiveo
...oh and nice car, i checked out the videos and i love your guages. orgasmic.
Old Apr 23, 2008 | 09:40 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
will it turn over? if so pour just a touch of gas in the throat of the carb and turn the key
Old Apr 23, 2008 | 09:43 PM
9tyfiveo's Avatar
9tyfiveo
ORIGINAL: rmodel65
turns over, and keeps turning over, and dumped gas in it. not even the slightest sign of life=[
Old Apr 23, 2008 | 09:47 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
remove the cap and check the points, plugs, wires cap and rotor button etc
Old Apr 23, 2008 | 09:56 PM
9tyfiveo's Avatar
9tyfiveo
ORIGINAL: rmodel65
will do. I have to go pick up some dinner real quick and will do. If that get's it running consider yourself $10 richer. haha I just want to get it running again. Its like a child with a favorite toy and no batteries for it to make noise. =[
Old Apr 24, 2008 | 01:21 AM
Stepman's Avatar
Stepman
I agree, it sounds like no spark, but I'd make sure first. Pull the coil wire off the dist, hold it about 1/8" to 1/4" from the engine and crank to see if it sparks. may want to see if it will lay by itself or hold it with something insulated.
Old Apr 24, 2008 | 01:41 AM
66JameStang
Yeah it sounds like no spark to me as well.... And thank you for the complement I love the guages as well and they work great. If you get tired of using gas you could also you starting fluid and just spray it in the carb and have someone roll it over... That should make for an easy start one it has spark ( if no spark is the problem)
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
MusicCity615
Sep 12, 2015 07:05 AM
uedlose
Sep 10, 2015 03:30 PM
