Tranny leak help
Old Apr 24, 2008 | 04:03 PM
straw1628's Avatar
straw1628
Default Tranny leak help
I have a C4 in my 66. There is a leak behind the bracket where the kickdown cable hooks on. I have been told there is an o ring behind there to replace. I was told if I take the nut off that I can pull a shaft out and replace it. How do I get the shaft out? I took the nut off last night, but I didnt want to start prying an wreck something. Thanks
Old Apr 24, 2008 | 04:10 PM
cprstreetmachines's Avatar
cprstreetmachines
Default RE: Tranny leak help
Take off the kickdown bracket and that should expose the o-ring. It's not the type your thinking of. It's more like a timing chain cover seal. Use a pick, pull out, put in new.Just hold the kick down arm to keep it from going in the tranny.
Old Apr 24, 2008 | 04:32 PM
straw1628's Avatar
straw1628
Thanks alot. It is that nylon looking seal? I looks like it has a split in it? Thanks.
Old Apr 24, 2008 | 04:37 PM
cprstreetmachines
If it looks split, there's you leak. But when you pull it out, it will be square from the sides. Only round looking at it from above, and it will be very hard also. Yeah, It will even feel like Nylon.
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
