Paint Stripper?
Old Apr 25, 2008 | 10:02 AM
drm_stang's Avatar
drm_stang
Default Paint Stripper?
I will be cleaning up the whole front clip of my mustang this weekend, will aircraft paint stripper also remove dried up dirt and greese?
Old Apr 25, 2008 | 11:11 AM
66JameStang's Avatar
66JameStang
Default RE: Paint Stripper?
When you say aircraft remover it makes me cringe... Prepare to be on fire unless you wear a body suit... Aircraft is what I used to strip the paint off my engine bay. It worked really well but I was hurting the whole time.
Old Apr 25, 2008 | 11:19 AM
Kramer's Avatar
Kramer
i used that stuff..... yea it burns the skin, works best when its warm. but that a wire brush and and some harbor freight paintbrushesh should get the job mostly done.... after that a shower to stop burning... i'm not too sure about dirt and grease. I shot everything with purple power to clean it before.
Old Apr 25, 2008 | 12:06 PM
TexasAxMan's Avatar
TexasAxMan
While it may remove the dirt and grease, you should clean the area first. Why use expensive stripper when you can use a cheap can of oven cleaner and a good strong stream of water?
Old Apr 25, 2008 | 01:22 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
if you use the stripper make sure to put some plastic wrap over it, this will make it not evaporate as fast and the product will work longer
Old Apr 25, 2008 | 11:35 PM
Kramer's Avatar
Kramer
took me 4 applications in 65ish degree weather today to do the interior rear quarter panels on my 64. partially because it was textured and it was painted black over white. i havent heard of the plastic wrap, darn
Old Apr 25, 2008 | 11:51 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yeah it comes from the trade little things i pick up but it does work
Old Apr 27, 2008 | 01:02 PM
straight68's Avatar
straight68
use castor oil to stop the burning of your flesh.
Old Apr 27, 2008 | 01:50 PM
67 evil eleanor's Avatar
67 evil eleanor
I used old brake fluid first with a brush and washed it off with a degreaser. Then two coats of stripper with a pressure wash after each. 99+% removal of all the paint down to the metal. The brake fluid softened up a lot of stuff (dirt, grime, grease and some of the paint) but you need to leave it on for a day or two. I like the brushable stripper the best. A good pair of rubber gloves and goggles helps. Careful not to breath the fumes.
guitarman376
Oct 11, 2015 01:47 AM
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
mustangchef
Sep 4, 2015 08:08 PM
