thermostat install
Old Apr 26, 2008 | 10:55 PM
baxsom's Avatar
baxsom
Default thermostat install
i just want to make sure i read this right.
when installing a t stat into a 289
it goes t stat spring side into intake hole
then the gasket
then the waterneck
Old Apr 26, 2008 | 10:57 PM
ky's Avatar
ky
America ftw
Default RE: thermostat install
no i think the spring goes in the water neck side.
Old Apr 26, 2008 | 10:58 PM
Mustangdemon67's Avatar
Mustangdemon67
the housing has a little indent in it where the thermo fits in. you need to put the thermostat on the housing where the indent is and then put the gasket over it. then once the gasket it sealed the thermostat will be attached to the housing, then its ready to go in the intake hole.
Old Apr 26, 2008 | 11:01 PM
ky's Avatar
ky
America ftw
put the thermostat into the water neck, apply silicone bead, apply gasket, apply another bead on other side of gasket, bolt on.
Old Apr 26, 2008 | 11:22 PM
baxsom's Avatar
baxsom
i just keep reading different procedures.
i know that the spring goes into the engine but i wasnt sure about the gasket.
i must not have got it lined up right right because i installed it intake>gasket>thermo>waterneck and it leaked like crazy.
guess i will try again, i didnt use any sealant so lets try that this time
Old Apr 26, 2008 | 11:44 PM
Mustangdemon67
it leaked because the gasket needs to be holding the thermo onto the housing, its makes a little sandwich with the thermo in the middle.
Old Apr 27, 2008 | 08:09 PM
Stepman's Avatar
Stepman
Sounds like you got it right, it just slipped. They can be a pain sometimes. Just make sure cone points to rad.
mtgldr
Feb 3, 2024 09:00 PM
Nick Oliver
Oct 17, 2018 04:22 AM
MusicCity615
Sep 12, 2015 07:05 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
