Horn Blew Out
Old Apr 27, 2008 | 07:54 PM
1970coupe's Avatar
1970coupe
Default Horn Blew Out
So i sucessfully installed an aftermarket steering wheel made by grant but not the classic style but while doing that i tryed to arch the two posts from my old steering wheel to test the horns and they worked the 1st try and the second time i believe i blew a fuse because it wouldnt do it again and when i installed the wheel the horn wont beep. So what are my possabilaties thati blew and what should i replace. I went to the autostore and they couldnt find me a horn relay and i dont even know where that is located. Please help! I would like to get it honkin.
Old Apr 27, 2008 | 09:47 PM
1970coupe's Avatar
1970coupe
Default RE: Horn Blew Out
CANNOT GET THE HORNS TO WORK. I BELIEVE I BLEW SOMEKIND OF FUSE OR RELAY SO I NEED SOME ADVISE ON WHAT TO REPLACE OR TRY TO GET THEM WORKING. PLEASE HELP ME OUT
Old Apr 27, 2008 | 10:43 PM
4reboy's Avatar
4reboy
there are no relays on the cars first of all, take a flashlight to the fusebox and see if a fuse is broken, from there I don't know what to tell you
Old Apr 27, 2008 | 11:28 PM
1970coupe's Avatar
1970coupe
ok well that kinda helps. I looked and i dont see anything on the fuse box for a horn fuse. Kinda odd. Any other suggestions? It worked when i arched it but the second time blew somethin and now it doesnt work.
Old Apr 27, 2008 | 11:53 PM
4reboy's Avatar
4reboy
well it won't be labeled "horn fuse" they are labeled by circuit. So if there is a blown fuse it could be affecting the circuit that the horn is on, as well as whatever else is on that circuit. Just make sure you give a thorough inspection of those fuses to be sure they are all good, then go from there.
Old Apr 28, 2008 | 12:06 AM
Aussie66Fastback's Avatar
Aussie66Fastback
mine arent labelled at all...have you got a wiring diagram for the dash stuff?
http://midlife66.com/wiring/wiring.html
towards the bottom of the page.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Oct 7, 2015 07:02 PM
mustangheaven
Sep 29, 2015 11:00 AM
daytooday
Sep 20, 2015 10:55 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
