Complete Ebrake setup?
Old Apr 28, 2008 | 02:25 PM
baddog671's Avatar
baddog671
Default Complete Ebrake setup?
My new differential will soon be under the car and I need tostart forming a gameplan for the ebrake system. I am going to retain the stock-style pull setup, but need some help on what I actually need..
I have the pull handle assembly, but the cable has been cut so I guess that needs replaced. Can someone find me a link for that cable and perhaps explain how it leaves the assembly as one cable, but somewhere splits into 2 cables for the brakes?
Also, if anyone knows, I have converted the brakes to discs. The calipers utilizethe single piston instead of having a separate ebrake assembly. Iheard I should use a set of LOKAR cables to hook this up, but, unsure on that...
Any help would be appreciated..
Nic
Old Apr 28, 2008 | 02:37 PM
Adrenolin's Avatar
Adrenolin
Default RE: Complete Ebrake setup?
Checkout NPD's online store - http://npd.dirxion.com/Main.asp
Click on Brakes and next page. Page 52 has a diagram and list of parts.
Might want to order 1 of their printed catalogs while at there site aswell. It has helped me out a lot.
Old Apr 28, 2008 | 04:23 PM
baddog671's Avatar
baddog671
Thanks for the link Robert! The diagram on there gives me a better image of how this works. I found a person selling a used assembly out of a 67 cougar that is "complete from handle to rear brakes." 100 obo
Old Apr 28, 2008 | 06:04 PM
baddog671's Avatar
baddog671
Anyone know how to remove the "stop-pin" in the handle's rod that stop you from pulling the rod clear out of the assembly? I need to remove it so I can replace the front cable, but cant get the pin out to remove the rod.
I assume it is just pressed in and needs beat out from the other directon...
Old Apr 28, 2008 | 06:38 PM
cprstreetmachines's Avatar
cprstreetmachines
here is a link to one that we did...
https://mustangforums.com/m_4815464/tm.htm
Old Apr 29, 2008 | 10:40 AM
zmetalmilitia's Avatar
zmetalmilitia
This was helpful for me.
http://www.mustangmonthly.com/howto/...ake_cable.html
jwog666
Dec 27, 2021 08:09 PM
ChampInSD
Oct 2, 2015 04:55 AM
fastbackford351
Oct 1, 2015 12:24 PM
guitarman376
Sep 30, 2015 05:54 PM
Drastang
Sep 29, 2015 03:31 PM
