Dead Gauges
Old Apr 29, 2008 | 04:38 PM
ThanksDad's Avatar
ThanksDad
Default Dead Gauges
I replaced my faded dash bezel last year. Ever since then I can not get my gauges to stay working.
After several attempts3 IVR's, new sending unitsand new guageswe determined it was a ground problem. I added a ground wire from the IVR to the frame. Started the car and was thrilled to have working guages. Then about a week later they died again. The Amp meter has always worked.
I am sick of replacing $27.00 IVR's and not having a gas gauge. Any idea's on what I should try next?
Old Apr 29, 2008 | 06:35 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: Dead Gauges
IVR = voltage regulator?
I believe the original ones were adjustable. Not sure if that can help you but since youve tried 3????
I hate auto electrics!!! My dash issues all came down to bad earth and the odd short. THe shorts blew fuses. The bad earth made the gauges do stoopid things.
All i can suggest is check the earth again...definately metal to metal contact and tight enough. I feel your pain[:@]
Old Apr 30, 2008 | 05:16 AM
ThanksDad's Avatar
ThanksDad
IVR is the Internal Voltage Regulator. It attaches to the back of the gauge cluster. There is an adjustment screw that is set and glued in place from the manufacturer. I checked to be sure my new ground was tight and had not come loose. It was nice and snug.
Someone told me they had seen something about making your own IVR for about $10.00 in parts from Radio Shack. Does anyone know anything about that?
Old Apr 30, 2008 | 06:46 AM
kalli's Avatar
kalli
from what you write do I understand correctly that once you replace the IVR it works fine and then stops a week later until you replace it again? So can we be sure that replacing IVR always resolves the problem? if yes, then we can go from there and maybe find why your car hates them ...?!
Old Apr 30, 2008 | 08:25 AM
65Coupester's Avatar
65Coupester
Before you replace the regulator, are you using a meter to determine that your getting 12 volts in and about 5 volts out? Don't rely on the gauges to tell if the regulator is working. Regulators shouldn't burn out that easy.
I had a problem with the ignition switch where the car would start and run but the gauges wouldn't work. When I jiggle the switch the gauges would come on.
Im using a 7805 voltage regulator in my car. I buy electronics in quantity, the regulator costs about 25 cents. At radio Shack the parts will cost less than 5 bucks.
Old May 1, 2008 | 06:21 PM
ThanksDad's Avatar
ThanksDad
Kali: Yes, when I replace the IVR the gauges work for a week or so. It's not a D/D so a week or so is anywhere from 20 miles to 50 miles of driving.
65Coupester: My Brother in Law is the electric guy for my car. I am going to forward this message to him and ask him about the voltage in and out. I do have a meter (I don't know to much about using it)and I know he used it to test a bunch of things the first time we got them working.
Old May 1, 2008 | 08:42 PM
az1966's Avatar
az1966
check the center wire on the ignition switch for connection/tightness,,,, the reason I say this is due to past experience ,,,if that sucker is kinda /sorta loose/tight ...your gauges and radio will go bonkers,,, YA I know it sounds crazy but everything else worked when this garbage was going on,, it seemed like the losse'ness would really mess things up even if you didn't go near the ignition switch
Old May 5, 2008 | 08:43 PM
ThanksDad's Avatar
ThanksDad
I found a Electronic IVR today that I'll think I'll try.
Old May 16, 2008 | 06:52 PM
ThanksDad's Avatar
ThanksDad
Just installed the new fancy $50 Electronic IVR. Let her idle in the garage for a few minutes and the gas gauge works. I didn't let her run long enough for the oil and temp to move.
Now my dilema is:
Do I dare take her out on the street -or-
never start her up again and always be able to say the *#@^$'s work
I'm going to the Ocean City Car Show tomorrow and taking the kids to 6 Flags on Sunday. So I'll have working gauges until at least Monday. Yeh Ha!!!!!
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
Thunderball
15
Nov 22, 2015 11:49 PM
jessicarabbit
Sep 25, 2015 12:41 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
