Header Clearance Issue?
Old Apr 29, 2008 | 06:20 PM
cgolden87's Avatar
cgolden87
Default Header Clearance Issue?
Ok guys here’s what I'm looking at. I have a 67 Fastback with a 5.0 from a 91 Mustang. My exhaust is a nice clean setup minus the glaring weakness of the stock manifolds. I am looking fora set of headers to complete it all, but my question is if I buy themfor a 91 am I going to have clearance issues when I go to install them in a different engine bay. It would be safe to assume that I will have different issues than the normal install.
Has anyone tried this with a similar setup, or has anyone who hasworked on a 5.0 swapped the headers and noted the difference in clearance? I was planning on using a set of shorty headers form Ford Racing that I liked, but I don't want to buy them only to find that they don't fit in my engine bay. So, any thoughts?
Old Apr 29, 2008 | 06:32 PM
groho's Avatar
groho
Default RE: Header Clearance Issue?
I believe the bolt pattern for a 5.0 and a early 289/302 are the same. I would contact thorley headers, or headers by doug and they probably already have a set made for this type engine swap. The key is clearing the bell housing,and powersteering,steering box and subframe. If you go to some low-buck header shop there's gonna be no promise they'll fit,especially because of the swap, and in some cases, you may get stuck with a set of crappyheaders and a lousy return policy. Go to a good shop that knows what they're doing and these two are some of the best on the market.
mtgldr
Feb 3, 2024 09:00 PM
Tivo304
Aug 28, 2023 12:19 PM
LivingInThePast
Sep 16, 2015 12:20 PM
BrantleyS550
Sep 14, 2015 04:18 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
