Posi or Not?
Old May 4, 2008 | 05:54 PM
1970coupe's Avatar
1970coupe
Default Posi or Not?
I jacked up my rearend today to paint my drums and im trying to figure out if i have posi or not. If i spin one wheel and the other spins the other direction does this mean i have an open rear? If both spin the same way then it would mean it has posi, correct?
Old May 4, 2008 | 07:12 PM
Mustangdemon67's Avatar
Mustangdemon67
Default RE: Posi or Not?
yup, that is correct
Old May 4, 2008 | 07:13 PM
1970coupe's Avatar
1970coupe
so if they go oposite directions then i do not have posi?
Old May 4, 2008 | 07:15 PM
Mustangdemon67
yup, no posi, i was in the same boat, was hopin it had it, but it didnt
Old May 4, 2008 | 07:26 PM
zmetalmilitia's Avatar
zmetalmilitia
Most stock stangs do not have posi, usually have the famous 2.79 gears open diff.
Old May 4, 2008 | 09:11 PM
dodgestang's Avatar
dodgestang
No stock stang and most modified stangs will not have a posi....that is afterall a GM term.
Wheels spinning in opposite direction = open diff
Wheels spinning in same direction = positive locking diff of some sort usually a trac lok (Ford) but could be a detroit locker, true trak, mini spool, or anyother number of brand names/types.
Old May 5, 2008 | 10:14 PM
flyingfool's Avatar
flyingfool
for those of you with the trac lok ect... how does it change the feel of the drive? cornering, launches and stuff. heard they make things quite torquey..(yay!)
Old May 6, 2008 | 07:49 AM
SalikDDD's Avatar
SalikDDD
lets just say, after i burned the clutches in my 8.8 this past sunday, a lot. try going from crappy 2.0 60' times to 2.6's - 2.8's and boiling the right rear off.
Old May 6, 2008 | 09:33 AM
kalli's Avatar
kalli
ORIGINAL: dodgestang
when you try spinning the wheels jacked up make sure you have the car in gear so that the diveshaft doesn't turn.
Doesn't make a difference to the results above but it might baffle you when the other tire doesn't spin at all (because the driveshaft does)
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
PipsBlackStang
Sep 28, 2004 08:18 PM
Ian70mustang
Apr 5, 2004 01:44 AM
DanH
Mar 21, 2004 01:01 AM
DanH
Feb 20, 2004 10:43 AM
