Tranny Leak
Old May 5, 2008 | 08:28 PM
unit91's Avatar
unit91
Default Tranny Leak
My 68 C4 tranny has a leak. Can't tell where it originates, but it drips from theU-joint. The rest of the tranny is dry, so I'm gonna assume it's the tail shaft. But, I pulled the drive shaft and the end of it is dry and so is the housing that the drive shaft slips into. ???? How hard is it to replace the tailshaft seal, if that's what it is?
Old May 5, 2008 | 09:19 PM
connor90's Avatar
connor90
Default RE: Tranny Leak
i think you should try some of that lucas oil tranny fix first...it works wonders. not sure how good it is for your car but its made by lucas so i assume its good for it and ive heard great things about it. of course thats only a temp. solution, but thats what i would do since im on a budget and wouldnt have time to fix just a leak.
Old May 5, 2008 | 09:24 PM
unit91's Avatar
unit91
I tried that. It stopped for a couple of days but started up again. I did notice that the fluid level is way over full. Wonder if that has anything to do with it? Maybe it's blowing out somewhere because it's too full ???
Old May 5, 2008 | 10:35 PM
Gun Jam's Avatar
Gun Jam
Did you check fluid level with the engine running and in park when hot?
IF not thats a false reading.
-Gun
Old May 6, 2008 | 07:53 AM
unit91's Avatar
unit91
Sure did. Any ideas?
Old May 6, 2008 | 02:17 PM
Stepman's Avatar
Stepman
If the trans is dry, it may be leaking thru the yoke, from right in front of the ujoint.
Old May 6, 2008 | 02:50 PM
Gun Jam's Avatar
Gun Jam
I think step called it.
How over full was it like 1/4 inch 1/2 inch or like 2 inches?
-Gun
Old May 6, 2008 | 04:07 PM
unit91's Avatar
unit91
It was about an inch or so over. So the yoke - is that the end of the drive shaft? Is that what the 'tail shaft' bushing is supposed to keep from leaking?
Old May 6, 2008 | 05:31 PM
65rangoon's Avatar
65rangoon
output shaft seal perhaps?
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
