'07 wheels on a '66
Old May 7, 2008 | 09:37 AM
fedrooster's Avatar
fedrooster
Default '07 wheels on a '66
I'm interested in putting a set of '07 Bullet style wheels on my '66 I know that I may need spacers up front to keep the tires from rubbing the inner wheel well. Also in back to even them up with the front. Has any one done or seen this, and can you direct me to pics of how it looks. I also need to know spacer size.I saw a guy did this to a 65 fastback inMustang Monthly several months back. He cut, sectionedand re-welded the wheelsto accommodate for the backspacing issues. I don't have the skill or money to do that. I'm going to get wheels and tires with less than 1000 miles for $500.00. I don't want to waste my time trying them out if it looks like crap.
Old May 7, 2008 | 10:07 AM
dodgestang's Avatar
dodgestang
Default RE: '07 wheels on a '66
$500 for the wheels with used tires
$200 for the 1.25 inch adapters to make them fit properly
$800 for newdecent/average tires since the ones on the wheels will be too tall
$100 mounting/balancing
_______
$1600 approx total cost
Old May 7, 2008 | 09:32 PM
petespokerplanet's Avatar
petespokerplanet
Dodgestang,
I bought a set of 1 in spacers from Dallas Mustang for the back. I heard that I would need a two inch spacer for the front, but will the 1.25 inch be enough for the front? Would you go with the 1.25 or 2 for the front?
P.S. your wheelguide is great, thanks for doing it and I look forward to version 2.0. (I'd be happy to contribute some picts of my setup as soon as I figure it out!)
Old May 8, 2008 | 09:12 AM
dodgestang's Avatar
dodgestang
ORIGINAL: petespokerplanet
Dodgestang,
Beats me
I don't know what wheels you have. Why on earth you would want to install 8 inch rims in different tracks on the car is beyond me personally. Measure the backspacing on the rims you have and it is very easy to figure out what size spacer you need.
Measured backspacingminus 4.75 on an 17x8 inch wheel will tell you adapter thickness needed(front and back)
Measured backspacingminus 4.25 on an 17x7 inch wheel will tell you adapter thickness needed(front and back)
Measured backspacingminus 4.5 on an 16x8 inch wheel will tell you adapter thickness needed(front and back)
Some additional research on my parts makes it appear that the 2007 wheels have a 44mm offset which is just shy of 6.25 inch backspacing....so you might actually need a 1.5 inch adapter to make that year wheel work! Please always measure the backspacing (or confirm through independant research like asking the seller to measurethe backspacing on any wheels you plan on buying prior to pulling the trigger on the wheels or the adapter)
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
