electric fuel pump
Old May 7, 2008 | 10:30 PM
bradleyb's Avatar
bradleyb
Default electric fuel pump
I installed a frontrunner serpentine system from Vintage on my 66 and have to use an electric fuel pump. I bought a Holley Blue and it is loud as hell, even back next to the fuel tank with Dynamat extreme throughout the car, it is still quite noticable until I start the car. My problem is that the pump puts out so much more pressure that I get little leaks where the filter is etc. (and the c-clamps are on there pretty tight - almost to the point where the rubber is coming through the slits). Should I locate the regulator in the back - now I have it right in front of the carb? Should I run another line that I "T" back by the pump and run a return line to the tank to take the pressure off?
Any thoughts would be appreciated, thanks.
Old May 7, 2008 | 10:45 PM
maverick75's Avatar
maverick75
Default RE: electric fuel pump
nothing can quiet those things up...i've used a red one with no problems...dont know about the blue ones.
Old May 7, 2008 | 11:03 PM
bradleyb's Avatar
bradleyb
Maverick, do you run a return line or have you experienced any issues from having excess pressure?
Old May 7, 2008 | 11:24 PM
Shrinkdude's Avatar
Shrinkdude
Do you have a carb system?
My Holley blue came with a regulator to get the pressure down to 4-5 psi. The blue is spec'd out at 14psi I believe.
Yes mine is loud too and I am considering going back to mechanical until I get my '86 302 ready to drop in.
Old May 8, 2008 | 12:11 AM
valley firearms's Avatar
valley firearms
I'm running the Holley blue. I quieted it down by mounting it on a rubber insulating pad. If your not used to it, it will still be noisy. I don't mind it myself since I only hear it inbetween turning the key on and starting the car. Before I was able to get the fuel psi regulated, it was definately blowing past my needle seats in the carb. You have to have a regulator for carbed applications. Also, invest in a liquid filled psi gauge.[align=left] [/align]
[IMG]local://upfiles/21693/099C2C0A95664D43B993AFC0283C2421.jpg[/IMG]
Old May 8, 2008 | 10:02 AM
urban_cowboy's Avatar
urban_cowboy
Most high pressure pumps require a bypass to survive. I am not sure about the Holley, but Barry Grant pumps use a bypass return either at the pump or after the regulator. A return line may help with the sound.
Old May 8, 2008 | 11:48 AM
bradleyb's Avatar
bradleyb
The blue came with a regulator so I should be good here and I screwed a liquid gauge in the open fitting on the regulator. My concern is that I am putting too much pressure on the line and wonder if I am going to experience a problem over time. Has anyone else had issues where the line connections had issues - now, my lines are just clamped with "c-clamps" instead of Russell type AN fittings
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
