Rust Filled with Poly
Old May 10, 2008 | 02:50 PM
myblackbeauty's Avatar
myblackbeauty
Default Rust Filled with Poly
I was thinking about buying a 1964.5 Mustang covertible. It looks great and I had an appraisal and inspection done on it. The inspection found a couple of small things (lighter didn't work, high beams didn't work, radio didn't work). The dealer said he would fix all these no problem. The inspector also found 3 areas where there was a poly fill from where they sanded out the rust. He said this was a common problem with older Mustangs and not a big deal as they look like they were repaired correctly. He still put a very high value on the car (~$38K) and said it was in great shape all around other than these issues. What do you all think? Is the former rust issue a serious issue?
Old May 10, 2008 | 03:26 PM
HGC's Avatar
HGC
Default RE: Rust Filled with Poly
Where was the rust? Do you know how thick the filler is? Probably is not a big deal. You are talking about a car almost 45 years old. Some rust repair is almost a certainty. Did they check the cowl for leaks?
Old May 10, 2008 | 04:26 PM
ThanksDad's Avatar
ThanksDad
38 seems awfully high to me. Now this is coming from a guy who was given a I6 Coupe from his Dad. I am interested to see what other people say about the price.
Old May 10, 2008 | 08:47 PM
Tony R's Avatar
Tony R
For 38K I would expect a show quality car.
Old May 10, 2008 | 08:54 PM
RedGTvert's Avatar
RedGTvert
ORIGINAL: Tony R
I'm with you. For $38K, I would exoect the car to at least have new metal and no fill. The only poly I would expect would be a skim coat.
Old May 10, 2008 | 09:03 PM
TripleHmotosports's Avatar
TripleHmotosports
What is the guy wanting for the car? Have the cowls been repaired? If the seller is asking anywhere near 38k for the car, I would think he would have already had those problems fixed. Would make me wonder what other short cuts were done. Did you find the Appraisal Company or the Seller?
Old May 10, 2008 | 09:15 PM
HGC's Avatar
HGC
ORIGINAL: Tony R
I think the appraiser set the value at $38,000. He didn't say what the asking price was.
Old May 10, 2008 | 10:10 PM
andrewmp6's Avatar
andrewmp6
The spots with the filler stick a fridge magnet to it if it don't stick then its thick probably a rust hole filled wrong.Yeah that much money car better be in top shape nothing wrong or not working.
Old May 10, 2008 | 10:27 PM
4reboy's Avatar
4reboy
since when has body filler been called poly?
Old May 10, 2008 | 10:28 PM
myblackbeauty
I think the cowl is OK. The fill was near the tire wells and one on a rear bumber.
