pushrods lifters
Old May 10, 2008 | 07:27 PM
unclebucktoo's Avatar
unclebucktoo
Default pushrods lifters
I recently acquired a 351C from a 73 Cougar. This motor has less than 5000 mi on a rebuild but it sat for six years ,but still runs GREAT ! I was pulling the 2 bbl intake off to replace with the Edelbrock Performer Thats supposed to be on it ( my brother in law said he couldn't afford the gas ).When I pulled the intake I found a bent pushrod and broken lifter. To the best of their knowledge its bored .20 over with a performance cam 300hp. I am just lookin for any suggestion as to what I should replace these with . I am going to do a complete pushrod lifter set .Thanks for any help
Unclebucktoo
Old May 10, 2008 | 07:59 PM
imnotmy77stang's Avatar
imnotmy77stang
Default RE: pushrods lifters
if the rest of them are fine just replace those two. why is the pushrod bent though? did the lifter collapse and then the pushrod bent? did a valve stick and cause it to happen?
Old May 10, 2008 | 11:04 PM
ky's Avatar
ky
America ftw
did it run with the bent push rod and broken lifter?
and you should only replace the 1 bad lifter cause if you get all new ones then you have to break them in. and the new ones arnt matched with the cam in terms of rubbing and wear.
Old May 10, 2008 | 11:24 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
10 bucks says someone over revved it, also the stock valves are 2 piece and like to come apart on cleves just warning you dont be to hard on it after this
Old May 10, 2008 | 11:48 PM
ky's Avatar
ky
America ftw
i didnt know valves come in two pieces.
Old May 11, 2008 | 02:41 AM
PJC Racing's Avatar
PJC Racing
You better start looking for the cause or you may just end up replacing the parts again.
Old May 11, 2008 | 03:10 AM
67mustang302's Avatar
67mustang302
+1
Definately find the cause. And yes, there are 2 piece valves where the head is welded to the stem and that's usually where they beak.
Old May 11, 2008 | 04:01 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yes i can vouch for that sadly the cleve i built still sits disassembled in my room[:@]
69Volunteer
Sep 30, 2015 10:39 AM
S'PortMustang69
Aug 30, 2015 08:27 PM
WDScott
Aug 17, 2015 06:38 AM
ding56
Aug 14, 2015 02:40 AM
Stinger
Mar 28, 2004 09:06 PM
