Primer on Primer
Old May 14, 2008 | 11:28 AM
Nick.Simonds's Avatar
Nick.Simonds
Default Primer on Primer
Well when I got my car the hood and front fenders were already primered.
My question, you not supposed to mix primers with paint from another company or whatever, right? Im going to paint with House of Kolors, and was wondering if a should reprime or lay a HoK sealer or something?
Old May 14, 2008 | 11:57 AM
1slow67's Avatar
1slow67
ROTM Moderator
Default RE: Primer on Primer
I really don't think it matters. I have never heard about not mixing with other companies.
Old May 14, 2008 | 12:00 PM
Nick.Simonds
That would make life easier.
Anyone else?
Also sealer goes over the primer right? Is it to late to touch up with spot putty, there are a few tiny nicks.
Old May 14, 2008 | 12:30 PM
zmetalmilitia's Avatar
zmetalmilitia
I know HoK has info sheets on their products that you can get from their website. I would follow their directions for use. I used their epoxy primer and then used their sealer. You can prime over another type or different brand of primer, just make sure the prep work is clean and scuffed right for properadhesion. I would use their sealer over the mystery primer to ensure the topcoat is happy. You usually have, after using the sealer, a few hours, upto 24hrs,to topcoat or else your stuck scuffing again.
Old May 14, 2008 | 12:34 PM
Nick.Simonds
Ok so get the primer all ready.
What grit should I use before the sealer, or is this stuff on theyre site?
Old May 14, 2008 | 12:36 PM
Nick.Simonds
Also do you have to sand down the sealer too, or just the primer?
Basically all you sand is the primer, then the clear when done?
Old May 14, 2008 | 12:50 PM
zmetalmilitia
I would scuff the primer with some scotch brite pads, nothing too abrasive, just scuff it to give something for the sealer to adhere to. Don't have to do anything to the sealer if the topcoat is applied within the recommendedtimeframe.
Summary:scuff the primer, cleanwith pre-paint solution to clean all dust off. Ihave used an alcohol/water mix which works good. Apply sealer.Wait for recommended time.(all on the pdf files from HoK website for each productyou are using). Apply topcoat-paint, base or single stage paint. If using base, then clear.
You have to know what you are doing if your using base/clear as it requires more skill to lay right. The single stage is just a paint that dries with a "clear coat" looking finish. You don't typically apply clear over primer or a sealer, I guess you could if that is what you want.
You can touch up anything. Now would be the time.
Old May 14, 2008 | 12:55 PM
Nick.Simonds
Lol not clear the primer. I was just saying the things you sand.
Old May 14, 2008 | 01:24 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
just hope the primer is not laquer or it will cause it to soften and lift when you apply an modern 2k filler primer. honestly if you dont know if it was prepped right id strip it
Old May 14, 2008 | 06:17 PM
Nick.Simonds
Looked on HoK, they save to strip it.
Problem solved.
guitarman376
Oct 11, 2015 01:47 AM
skiprCH
Sep 15, 2009 10:00 AM
pak133
Sep 22, 2005 12:02 AM
Jugador
Jul 11, 2004 04:31 AM
