Too much brake booster?
Old May 20, 2008 | 05:50 AM
Rookie68's Avatar
Rookie68
Default Too much brake booster?
Is it possible to have too much boost from your brake booster immy 68'.The reason i ask is because WhenI apply the brakes They are extremely "mushy". I can't even feel the brakes contact the rotors in the pedal.The brakesdo apply when driving down the road however, which will stopin a hurry but the pedal wont close the contacts on my brake switch due to no resistance in the pedal from applying the brakes. If anyone has any suggestion it would be greatly appreciated.
I have front disk /rear drum
Old May 20, 2008 | 08:29 AM
davesanborn's Avatar
davesanborn
Default RE: Too much brake booster?
Something is wrong.
My first thoughts are that you have air trapped in the brake system. Your pedal should not feel "mushy". It should be "hard as a rock".
Removing ALL of the air from the brake system is not always an easy task. This last car that I built took over a gallon of brake fluid, vacuum bleeders, reverse bleeding, etc., etc. and I've got a good feeling that there's still a little bit of air still trapped somewhere in the system.
Dave
Old May 20, 2008 | 10:55 AM
Rookie68's Avatar
Rookie68
I suppose it could be air. Im not so sure though since when the car is off and you pump it several times your pedal is "hard as a rock". Ive dealt with air issues before and this is doesnt seem quite the same.
Old May 20, 2008 | 03:10 PM
davesanborn
This happens because you are actually compressing the air that's trapped within the system. Remember your basic physics.... air will compress, fluid will not. You should not have to "pump" the brakes to get a hard pedal.
I'm more sure now than I was before... you have air in your brake system.
Dave
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
