302 HEAD SWAP
Old May 22, 2008 | 07:00 PM
TISCHROCKS's Avatar
TISCHROCKS
Default 302 HEAD SWAP
I'm putting together a 302 for a 68 mustang. The stock heads needed valve guides so while that was being done if found a set of gt heads off a 351 ford lightning. will these head work on a old 302 block? I know they will bolt up , but will everything else. I was told the headers won't work.the head bolts are to big. any help would be great.
TISCHROCKS's Avatar
TISCHROCKS
Default RE: 302 HEAD SWAP
Old May 22, 2008 | 07:17 PM
imnotmy77stang's Avatar
imnotmy77stang
double posts suck eh?
GT40 heads from a lightning have the same spark plug location and same exhaust pattern as any 302 so your just fine there - its the GT40P's that have a different plug angle which makes the spark plugs hit regular headers.
in regards to the head bolt holes, you can buy bushings made specifically for using heads designed for a 351w on a 302, but honestly all you NEED to do is use grade 8 washers under the heads of the 302 bolts - the two alignment dowels will keep the heads centered on the block and all bolts do is clamp the two parts together.
your intake ports will be slighty larger, you'll need to use intake gaskets from a 69 era 351w - and if you port match your intake manifold to the new larger ports in the heads you'll help take advantage of the gains you'll see from these heads.
oh yeah, and welcome to the forums
Old May 22, 2008 | 09:51 PM
tyler72's Avatar
tyler72
Well, while washers might work ok, I would suggest getting the bushings. It is the correct way to do it and is inexpensive. The bolts do help hold the head centered, so I wouldn't just use washers.
Old May 22, 2008 | 09:55 PM
67mustang302's Avatar
67mustang302
If it's setup for 1/2" head bolts, I'd run the ARP 1/2-7/16 reducing head bolts.
Old May 22, 2008 | 11:22 PM
Starfury's Avatar
Starfury
+1.
You need to replace the head bolts anyway, and that's a better way to do it than using bushings. And yes, you really do need to use either bushings or the ARP reduction bolts. Those alignment dowels are there to line the heads up during installation; they're not designed to take any kind of load. The head bolts are what keep the heads in proper alignent while installed.
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
wraith777
Sep 28, 2015 10:49 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
