Engine issues
Old May 23, 2008 | 09:21 PM
jonm1a1's Avatar
jonm1a1
Default Engine issues
My 289 blew up in my 65 stang it was over heating really bad and i did eveything to try and solve the problem. Why taking it apart we found out it was boreded over .40. i Really do belive that is why it would run hot.
Well now i have a hole in my piston wall and the only way to fix the engine is to sleeve it and bore it .60 and i really think that will make things worse.
so......questions
1. does anyone think the .40 was the reason it was over heating.
2. should i keep the engine since it is the one that came with the car?
3. i have a 79 302 that i can put in it. should i do that or a 66 289 block i found for $100.00 that i would also have to rebuild.
Old May 23, 2008 | 09:35 PM
jonm1a1's Avatar
jonm1a1
Default RE: Engine issues
so?
Old May 23, 2008 | 10:12 PM
mustanglover66's Avatar
mustanglover66
I would tose that block .060 over is pushing your luck since you were having heat problems at .040. I sold a 79 302 block to a recyler we deal with alot. I only got $50.00 for it because 79 was not a good year for 302s. Check the bore size and wear in the 66 if it can make .030 or less I would say go for it.
Old May 23, 2008 | 10:33 PM
ky's Avatar
ky
America ftw
i found my standard bore 302 block for $50. came outta a 69 bronco. just find one on craigslist and take a pair of calipers to check the bore if you find one.
dont sleeve the block and bore to .060 its junk now.
Old May 23, 2008 | 10:34 PM
ky's Avatar
ky
America ftw
oh just saw you have a 289 block. i say get that block and rebuild it .030 over.
Old May 24, 2008 | 02:36 AM
65Coupester's Avatar
65Coupester
I have a 289 that was bored 60 over and it runs cool. No problems.
Since the 79 302 motor is paid for that is a plus for it.
I wouldn't put alot of cash into an old motor unless it was original to the car, which your aint.
If you get a newer block, say after 87, it will have roller lifters and a modern cam grind. That is more of a plus.
Old May 24, 2008 | 08:25 AM
jonm1a1's Avatar
jonm1a1
ok thanks guys
Old May 24, 2008 | 09:13 AM
imnotmy77stang's Avatar
imnotmy77stang
your 302 block + your 289 crank and rods = 289
dont sleeve and take it to .060, and no i dont think .040 is what caused it to overheat
djbigskrilla
Sep 20, 2022 01:04 AM
P51_GT
ROUSH Performance
24
Apr 6, 2019 09:19 PM
drfister
May 3, 2018 10:38 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
mweiland
Aug 13, 2015 05:11 PM
