wet sanding
Old May 26, 2008 | 09:56 PM
Tony R's Avatar
Tony R
Default RE: wet sanding
its what the paint shop recomended and that brand also had a wider variety of grits to choose fromon their shelf.
Old May 26, 2008 | 09:57 PM
HGC's Avatar
HGC
ORIGINAL: Tony R
I've been using Mirka.
I would think any name brand like 3M or Mirka would be OK as long as it is made for cars. No-name or store brand will probably not last as long and may not really be very uniform. It would not suprise me if cheap paper could have impurities which could leave streaks or deeper scratches. If you think about it, fine grit sandpaper is a pretty exacting product and it is probably a good case of "you get what you pay for."
Old May 26, 2008 | 10:05 PM
Tony R's Avatar
Tony R
It has held up fairly well. I havent noticed the sand coming off the paper like in some of the cheaper brands that I used on my truck. I also like the fact that it comes is sticky rolls so I dont wear out my fingers trying to hold the paper to the blocks.
Old May 26, 2008 | 10:09 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i prefer wet sanding on my personal cars. but in a shop its hardly used anymore 99.9% is done dry. i like doing it wet mainly because its easier for me to feel imperfection under my fingertips and you dont get all dusty. i just throw on a pair of sandals and shorts and go to town
Old May 26, 2008 | 10:21 PM
jaw66's Avatar
jaw66
In reply to rmodel65 I have the opposite problem as you I tend to miss more imperfections when wet sanding than dry. I just dont feel the panel as well when it is wet. I do like that the wet washes all the dust away as you sand. One of the guys I work with has to do it wet to get the better job. Yet we both come out with the same quality in the end. I worked with the one guy for awhile and he had to use a rag in order to feel it properly. This is only meant as an observation on different styles.
Old May 26, 2008 | 10:26 PM
HGC's Avatar
HGC
ORIGINAL: rmodel65
PLEASE...do not post a picture of that!
Old May 26, 2008 | 11:33 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ok, well i am in south ga[8D] j/p, seriously i prefer to do it so i dont stay wet all day. another way i se to look for imperfections is wipe the panel down with wax and grease remover and look at it from an angle
importsmasher
Oct 9, 2015 04:42 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Sep 8, 2015 11:50 AM
SterlingStunner
5.0L V8 Technical Discussions
Sep 4, 2015 06:28 AM
NeoTokyo
Apr 11, 2004 12:57 PM
