Radiator fan question?
Old Jun 6, 2008 | 01:13 PM
pwrl3ss's Avatar
pwrl3ss
Default Radiator fan question?
As I'm starting to learn, working on a classic Mustang is a never-ending adventure. Well, I got my disc brakes in, went out for atest driveand my radiator started to leak. So, I went ahead and bought a 20in aluminum replacement. Looking at the fan that is in there, it has 4 blades and there isn't a shroud. The fan looks a little "wimpy". So while I'm at it, I think I want to replace that fan as well. I don't want to go with an electric fan (at least not yet because of $$$) but I want to get better cooling. But looking at the different fans (5 blades oem-types to flex-a-lite) I'm not sure what to get. And would a fan-clutch help me out?
Thanks
Old Jun 6, 2008 | 02:19 PM
tyler72's Avatar
tyler72
Default RE: Radiator fan question?
I have a factory 5 blade flex fan on mine. You should just go get a flex fan from a local parts store. It will pull a lot of air all of the time because the fins will be curved at idle, but will flatten out some when the engine revs, which saves you HP.
Old Jun 6, 2008 | 03:03 PM
baddog671's Avatar
baddog671
I just converted mine to electrical and it wasn't very expensive at all. I think total I spent about 125$ for a 14" Hayden fan and adjustable thermostatic regulator. I installed it as a pusher, if I need more cooling power down the road, I'll mount a 16" or 17" as a puller to help.
Old Jun 6, 2008 | 06:07 PM
groho's Avatar
groho
ashroud will do wonders to help direct the air flow if you decide to use a conventional fan. I'd consider buying the shroud with your current set up, they're very inexpensive.
Old Jun 6, 2008 | 08:18 PM
merr818's Avatar
merr818
^+1 I bought mine from CJ pony parts and it was relatively inexpensive for a factory reproduction peice. It worked really great that night then I blew the motor.
Old Jun 6, 2008 | 10:48 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
get a shroud and a flex fan
Granatelli Sales
Jan 20, 2020 12:34 AM
Beerman309
Sep 19, 2015 01:16 AM
jaiidutch
Sep 14, 2015 10:29 AM
MusicCity615
Sep 12, 2015 07:05 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
