T5 swap ... back up lights switch?
So just finished the T5 swap ... everything went quite well and the first test drive on the interstate was good ... very different from a 4 speed toploader
Question : is there a kit to be able to hook up the back up lights?
Thanks
Thanks
Good news......you don't need anything. The positive wire going to the rear lights, I connected it to one side of the switch with a bullet connector and the other side of the switch, I connected to an on/off positive wire in the fuse box. Thats it. Hope I helped.
I grabbed a couple of connectors that Ford puts on their oil pressure units from a couple junk cars and hooked them the same as above. Make sure the power source turns off with the ignition or your lights might stay on all the time parked in reverse.
bond007
Aug 26, 2015 11:36 PM
Fixed!
