Old Oct 23, 2015, 11:56 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
key stuck in on position
Old Jun 13, 2008 | 01:34 PM
66 girl's Avatar
66 girl
Default key stuck in on position
I finally had the stereo installed y'day. I didn't make it outta the parking lot without blowing a fuse, but the tech fixed it.
Today, first trip out, I get to where I'm going, and I cant turn the car off - the key is stuck in the on position. The ignition is pretty loose, where as it wasn't y'day. So I go back to the tech, who says "Yeah, I thought you knew about that - I had to really play with it to get the key out". Ugh.
DUring the install I watched him with the altmeter in the ignition a bunch of times. Could he have loosened it enough that now I have to replace it? I know the car is 42 years old - so am I.
Ok, the punchline - how do I get the key out if it happens again,,, Im not gonna keep running back to the stereo tech. Is there an adjustment to make? thanks.
Old Jun 13, 2008 | 02:30 PM
vineman's Avatar
vineman
Default RE: key stuck in on position
yeah if anyone has any suggestions i could use the help to, not to steal the post, my key too is stuck in the ignition and will not go to the "off" position so i can pull it out.
Old Jun 13, 2008 | 02:42 PM
Gun Jam's Avatar
Gun Jam
If you guys are having trouble extracting the key it might be time for a new ingintion tumbler setup. The part that the key fits into is a small removable cylinder that has the guts in it that are matched to your keys.
My only suggestion is to disconnect the battery and then with the key in the off position insert a small paper clip into that tiny hole just below slot for the key. Then press in the paper clip and rotate the key to the ACC position and that cylinder should pop out like the cigarette lighter.
Then go and get a new one somewhere.
if you cant rotate the key to the ACC position then Im not sure what you need to do.
-Gun
Old Jun 13, 2008 | 02:56 PM
jlg2002's Avatar
jlg2002
Sometimes a little lock fluid, available from ACE hardware, sprayed in the keyway will unstick the problem tumbler and let the key be removed. It's not that easy to spray cleanly if the key's in it but it will go in. other than that, time for a replacement key and cylinder( may even have to replace the entire switch if you can't get the old cylinder out),
(don't forget to lubethe new cylinderwith lock fluid)
Old Jun 15, 2008 | 12:34 AM
vineman's Avatar
vineman
well damn, was kinda hopin to keep the original keys with her
Old Jun 15, 2008 | 12:35 AM
Gun Jam's Avatar
Gun Jam
might be able to make a tumbler to fit your keys but i dont know.
-Gun
Old Jun 15, 2008 | 12:48 AM
jaw66's Avatar
jaw66
Any locksmith can rekey a new unit to your old keys. We have to do this at work all the time when working on stolen recoverys. Also if you have say to mustangs that take the same style key (the double sided one) you canhave each side of the key cut differently since the tumblers only read one side of the key and viola one key for two cars. you just have to flip the key for the car you want to drive.
Old Jun 15, 2008 | 02:02 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: vineman
your steering column is probably out of adjustment look near the bottom and see if the linkage is still attached to the rest of the tranny stuff if not push it all the way up should free the key
and gor 66 girl im gonna go with everyone else you probably just need a new key and tumbler
Old Jun 16, 2008 | 02:55 PM
jlg2002's Avatar
jlg2002
ORIGINAL: rmodel65
ORIGINAL: vineman
If she had a model with a ign switch in the column your suggestion may have worked.
Old Jun 16, 2008 | 03:56 PM
66JameStang's Avatar
66JameStang
I actualy had the same thing happen to me, I just played with it till it turned... it eventually would turn no more so..... I ripped it out with a slide hammer[sm=badbadbad.gif] and dropped the rest of the ignition
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
logan409
Sep 26, 2015 07:43 PM
jstrothe
Sep 24, 2015 12:17 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
