window trim
Old Jun 19, 2008 | 08:27 PM
project.65's Avatar
project.65
Default window trim
the trim around the drivers side door window popped off the top. the rubber/seal is old, hard, and was breaking off so i took itout. most of the trim is stillin place with the window except for the top of the window.how can i fix this?i can find the rubber/seal anywhere.
Old Jun 20, 2008 | 01:53 AM
project.65's Avatar
project.65
Default RE: window trim
anyone
Old Jun 20, 2008 | 10:40 AM
davesanborn's Avatar
davesanborn
Well....
Can you be a little more specific about which trim you're talking about?
[quote] the trim around the drivers side door window[/quote]
The only trim around the drivers side door window is made of stainless steel. Rarely will this "pop off" as the glass is firmly pressed into the stainless steel channel and sandwiched with a thin rubber seal called "glass sealing strips".
Is this the rubber seal you're referring to?
I can help you, I just need to know exactly which pieces you're talking about.
Dave
Old Jun 20, 2008 | 10:43 AM
zmetalmilitia's Avatar
zmetalmilitia
If your taking about the metal piece on top of the window, usually any glass shop will stock what you need. That will probably be the quickest way of findng what you need. I believe it is more of a sticking tape like seal.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
b8checker
Oct 8, 2015 12:55 PM
mdg
Oct 1, 2015 07:04 AM
b8checker
Sep 30, 2015 07:11 AM
