convertible motor mounts different?
Old Jul 2, 2008 | 11:55 AM
109jb's Avatar
109jb
Default RE: convertible motor mounts different?
If it has to go up, how about spacers between the block and the mounts. Not ideal, but would get you going.
Old Jul 2, 2008 | 12:42 PM
jamieNerikas66stang's Avatar
jamieNerikas66stang
this is what i am going to do tonight,...i cant take this messing around with wrong parts any longer,..
Old Jul 2, 2008 | 01:57 PM
cprstreetmachines's Avatar
cprstreetmachines
ORIGINAL: jamieNerikas66stang
HAHAHAHA. Please tell this to my customers when I tell them it will take another 2 days before they can have their cars back. I don't think they really understand our frustration.
Old Jul 2, 2008 | 02:11 PM
jamieNerikas66stang
ill tell you what,...i will take a picture of the hole i punched in the wall and a picture of the open end wrench i threw half way through the wall that is still sticking out,..and you can print out copies with a nice title and hand them out,...
Old Jul 3, 2008 | 04:16 PM
jamieNerikas66stang
ok, frustration level has went from 6ish to about 19 on a scale of 10,...
so once again i set off to remove the motor mounts without removing the engine or anything,..wiggle out the mount, install about 9 washers and a longer bolt,..just to see if this would work, install and tighten everything, lower the motor, and WTF i have made it worse,..i guess by installing the washer it has lifter the front half of the motor up, pushing the back half down onto the center link...
this make me almost think its something with the trans mount,...i think i need the spacers inbetween the trans mount and trans body mount,..to push the rear half of the engine up,...
and i looked at the ron morris mounts, and NO WHERE does it say height adjustable,..it says front to back and side to side
Old Jul 3, 2008 | 06:33 PM
68EFIvert's Avatar
68EFIvert
Ron Morris has two style of mounts. One with stock height and one 1/2" lower. Both are adjustable forward and sideways. Just select which height you want on the order screen.
http://www.ronmorrisperformance.com/...y_Code=Hot_New
Old Jul 3, 2008 | 10:32 PM
noroof66's Avatar
noroof66
1965/66 Convertible mounts are1 inch taller.Surprised you stll needed 1/4 inch after the correct mounts.
Old Jul 4, 2008 | 07:07 AM
jamieNerikas66stang
where do you find these mounts?^^^^ you speak of, can you send me a link, cause i dont think i have the right ones to begin with!
Old Jul 4, 2008 | 03:51 PM
jamieNerikas66stang
hey noroof66 where did you go? where would i find a set of these/
Granatelli Sales
Jan 20, 2020 12:34 AM
spamedic
Sep 9, 2015 12:15 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
