Rust Converters?
Old Jun 20, 2008 | 08:08 PM
pnandy's Avatar
pnandy
Default Rust Converters?
ok so my paint inside the cowl has started to chip away and so some surface rust has started to develope i can't and don't want to open up the cowl is there a good rust converter i can spray in there to fix this up its been a Ca NV car its while life so i doubt theres any other rust going on i would like to use picklex 20 but does anyone know of better rust converters i could get into the cowl im planing use this stuff then spray some dudlicolor bedliner in ther after wards thanks for the help in advance
Old Jun 20, 2008 | 08:28 PM
JamesW's Avatar
JamesW
Default RE: Rust Converters?
There's multiple products out there. Most are a Phosphoric Acid deritive that when applied to the rust (iron oxide) hardens into an inert Iron Phosphate. Some items such as Ospho can be put in a spray bottle and sprayed onto the surface. Other are more paintlike and have to be brushed on. Your situation inside the cowl is a bit of a situation, as it's hard to brush. You can spray, but then you need to brush off the loose material afterwards somehow before applying the bedliner.
Old Jun 20, 2008 | 08:36 PM
pnandy's Avatar
pnandy
ima tape off the cowl vents pretty good before spraying it and was just thinking of using a pipe cleaner to brush off the extra material has nayone heard of picklex 20 ive seen some before and after picks on a rambler forum that look real good it comes in a spray bottle to begin with and is why im leaning towards it and i can get it on ebay for a decent price
Old Jun 20, 2008 | 10:06 PM
Tony R's Avatar
Tony R
i use rust mort. the only real problem is that after you put the converter on and wash it off like the directions say it will rust again immediately. I am not on my personal computer so I cant post pics of what it does.
Old Jun 21, 2008 | 08:14 PM
pnandy's Avatar
pnandy
any pics tony R
Old Jun 21, 2008 | 11:17 PM
Tony R's Avatar
Tony R
look at my roof replacement thread and there will be some in there at the end of the thread.
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
guitarman376
Sep 30, 2015 05:54 PM
b8checker
Sep 30, 2015 07:11 AM
