Motor Mount Torque Specs
I have a '66 200 I6 and I was just wondering if anybody knows the torque specs for the motor mounts? When the car Idles the engine shakes violently and then when you give it some gas and get into higher RPM the shakin stops. Somebody suggested to me that I check the motor mounts but I need the torque specs and can't find them anywhere. Thanks
Easy enough, tight. The shop manual says: Whew ther'es a buch of 'em:
(all the fronts)
front insulator to engine.... 18-24 ft-lbs
insulator to support bracket..25-35 ft-lbs
Bracket to body.................. 20-28 ft-lbs
(all the rears)
insulator to rear support........25-35 ft-lbs
insul to support extension.......20-30 ft-lbs
rear trans support.................20-30 ft-lbs
rear suppt to body...............10-20 ft-lbs
insul to trans.......................20-30 ftlbs
It's up to you to find em all
(all the fronts)
(all the rears)
Check the engine mounts for cracks too (if you haven't already), I liftedmy carand found some cracks in mine and swapped them out with the Ron Morris mounts. That fixed a little bit of the vibration problem that I had.
jwog666
Dec 27, 2021 08:09 PM
logan409
Sep 26, 2015 07:43 PM
mrappe
Sep 26, 2015 10:16 AM
LivingInThePast
Sep 16, 2015 12:20 PM
Tight enough to where they won't back out, but not so tight they break, hehe.
