Radiators, more questions!
Old Jul 7, 2008 | 10:28 AM
zmetalmilitia's Avatar
zmetalmilitia
Default RE: Radiators, more questions!
I'll have to see how much room, width wise, I can go before I start running into my battery tray. I can mod the rad support if needed. Thanks! I think I will seriously look at the summit radiators or AFCO.
Old Jul 7, 2008 | 11:14 AM
Iskwezm's Avatar
Iskwezm
The Summit brand is made by Northern.I have a 28X19 in mine.
Old Jul 7, 2008 | 05:26 PM
jakstang's Avatar
jakstang
I installed a Summit (Northern) 28 x 19 on mine...
Old Jul 7, 2008 | 10:02 PM
zmetalmilitia
Would you have preferred both ports on the passenger side? How does the single fan cool? Looks like a 13 incher? No battery there either, a fitment issue? Nice.
Old Jul 7, 2008 | 11:30 PM
JMD's Avatar
JMD
That one looks pretty nice. Did you make the fan mounts or buy them? I like um.
ORIGINAL: jakstang
Old Jul 8, 2008 | 01:06 AM
jakstang's Avatar
jakstang
Thanks...I wanted a crossflow due to its improved cooling capabilities when compared to a down flow radiator...The fan is a flexalite 16" and it works well, it looks kind of small due to the size of the radiator...Yes the battery was relocated to the trunk because the radiator is significantly larger than stock, I could have left the battery in the stock location by shaving the tray by an inch or so, but I opted to go the complete mile and relocate it...The electric fan mounts are from summit.
http://store.summitracing.com/partde...p;autoview=sku
Old Jul 8, 2008 | 11:46 AM
69FB's Avatar
69FB
Very nice. When I bought my Mustang the radiator was attached using zip ties. [&:] Yours looks much better. Car is still in the shop getting all the little things fixed. The battery was mounted in the trunk, but I opted to have it moved back to the front. I also was thinking of changing to an electric fan. Your setup is very clean looking. I'll have to check out their fans and radiators. I have an al radiator now but I will eventually want to go with a crossflow for the same reasons...it gets hot here in AL like it does in FL. Since most of my driving is in the South from Texas to Florida I want to make sure it stays cool without any threat of overheating.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 30, 2015 03:48 AM
treesloth
Sep 28, 2015 07:03 AM
