Got MPG?
Old Jul 8, 2008 | 09:13 AM
67BullittCoupe's Avatar
67BullittCoupe
Default RE: Got MPG?
also change yoru driving habits.
driving 55 versuse 70 uses 15% less gas.
my ford fusion will get 35 MPG doing 55, at 70 im getting 28-30.
multiply that by 15 gallon gas tank thats 75 extra miles to the tank full. you basicallyl save 2.5 gallons of gas. thats 10$ every time you fill up.
it takes 60 dollars to fill yp my jeep, id love to save 10 bucks everytimg.
Old Jul 8, 2008 | 09:14 AM
67BullittCoupe
not to double post but i should also mention i hear that a ford fusion going 100 on I4 going to Tampa will still get 22 to the gallon.
not that i would know from experience.
Old Jul 8, 2008 | 11:10 AM
Starfury's Avatar
Starfury
ORIGINAL: 67BullittCoupe
+1
Classic Mustangs aren't much more aerodynamic than bricks (.54 drag coeffecient vs .64, iirc). The faster you go on the freeway, the more drag you create and the worse mileage you get. Depending on gearing, optimal speed is usually around 50-65mph.
Old Jul 8, 2008 | 08:20 PM
baddog671's Avatar
baddog671
www.gassavers.org is a good forum for fuel conserving enthusiasts. I'm a member there and would regularly get my old DD in the 50's mpg range.
The biggest improvement you can make is driving habits. Watch your overall speed and no jack rabbit starts are probably the best...
Old Jul 9, 2008 | 06:29 PM
ebluekeys's Avatar
ebluekeys
I just got back from a trip - Cinci Ohio to Central Jersey and back - 1250 miles round trip. Got 20 MPG!! I was VERY surprised. STock 2.79 gears with posi installed. 289. Edelbrock performer manifold and 500 CFM Performer Carb with electric choke. Chinese HEI Ignition ($60 ebay) and 2 inch dual setup with H pipe. C4 auto transmission with full race shift kit. Healthy motor rebuild. Can light 'em up in 1st and healthy chirp in 2nd even with the 2.79 rear!! Fun car to drive. Getting ready to install shorty headers and an X pipe ahead of the mufflers. Can't wait to see the improvement in noise reduction and extra HP.
Old Jul 10, 2008 | 05:18 AM
dano670's Avatar
dano670
I swapped in the AOD and with my 2.80 rear end, I get 20 mpg on the highway at 75 mph or so. I have heard that my car is over geared because it runs near 1500 rpm at 60 mph.
squishbang
Dec 4, 2015 02:29 PM
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Scottyboy187
Nov 5, 2015 04:18 PM
algregory
Sep 11, 2015 11:44 AM
Cin K
Sep 2, 2015 07:50 AM
