Rear End Gearing?
So I have the new motor in....
a 302 bored out to a 306 pushing about 350 HP........
i have a C4 tranny
but what rear end gear ratio shouldI be using?
I want it to be Fast off the line, but i also want to be able to cruise down the highway at the same time?
Any recommendations?
i have a C4 tranny
how much driving on the freeway vs city and speeds below 65 mph? How tall is your rear tire?
I had 3.00 that gave me 3200 RPM at 80mph I wouldnt have wanted it any higher thats for sure but then I did almost as much freeway driving as i did city driving.
If you mentioned the word highway like I see you did I wouldnt want anything above 3.25s... but im a pansy. 3.25s would give you 3600 rpm at 80mph with 25" tall tire.
-Gun
-Gun
good 70% to 80% would be city driving / below 65 mph.
As for the tire hieght..... well I havent picked out rims or even thought of that.
but i think im going to go with a 17 inch in the rear and maybe a 17 or a 16 in the front, all tires would be like a mid profile tire, definitely not low profiles.
well your rear tier height makes a big difference. You might get away with 3.50s based on driving style and a tire that sounds like it will be a bit larger than 25"
Lets say for fun that your tier was 27" tall and you were at 60 mph and had a 3.50 that would give you 2600 rpm but at 80 mph it would be 3500 which is not so bad
-Gun
-Gun
I just asked this a couple of days ago (search is broken, so you probably didn't see it):
https://mustangforums.com/m_5238714/tm.htm
Check out the thread on axel ratio. Deja vu.
I got sound advice from Gun, but ignored my gas gauge and gun's advice to stick with the lower gear and went with a set of 3.37s. I've driven other cars with a similar drivetrain and tire and 3.50 gears are doable if it's mostly a town car. A lot of this is personal choice. I'm hoping to feel the responsivness without burning twice as much gas. We'll see after I feild test it.
Good luck.
Carlos
Good luck.
Carlos
Thinking about this for me too, not to thread hijack, but I have the windsor block, abuilt c4, and do probably 50/50 freeway and city driving, and want something with traction lock... looking for some suggestions too. I'll go measure my tire height in a bit
I've used the linked "tire diameter calculator" for a few years and although actual tire diameters vary slightly between manufacturers, the calculator come in very handy.
http://www.users.fast.net/~blazer/tirediam.htm
Dave
Dave
musnicki
Sep 23, 2015 07:11 AM
inyadreems
Aug 21, 2015 09:10 AM
