Electrical Grounds
Old Jul 11, 2008 | 07:15 PM
Cogtx's Avatar
Cogtx
Default RE: Electrical Grounds
Got a pic of my ground from the starter to the firewall...
[IMG]local://upfiles/19071/3CBCB55BA009436AB438AB594B011AC7.jpg[/IMG]
Old Jul 11, 2008 | 07:58 PM
baddog671's Avatar
baddog671
What if you run the ground from the negative terminal to the chassis, instead of running it from the negative terminal to the front of the block?
Old Jul 11, 2008 | 10:08 PM
67 evil eleanor's Avatar
67 evil eleanor
Bad grounds can cause a host of problems. I like the use of star washers when grounding circuits (like Ford used throughout the car). I run the ground from the battery to the chassis and then to the engine block VIA a ground strap (It needs to bethe equivalentof a 4 AWG). If you run an MSD or other spark unit, then another wire should be run from the unit to the negative side of the battery.
Old Jul 11, 2008 | 11:54 PM
drm_stang's Avatar
drm_stang
Finally got the car running again. Ran one 4 awg ground from the battery to the engine block, another from the fire wall to the engine. Both grounds use 4 awg gold connectors. Really works well, regulator does not flicker like it did before i pulled the engine. Spark is right up to par now as well. Just have to get the outside sheet metal put back on.
Thx Guys
Rob
Old Jul 12, 2008 | 12:26 AM
Toddman0025's Avatar
Toddman0025
ORIGINAL: drm_stang
Thx Guys
Rob
I think this is going to be added onto my "to do" this list weekend...
Did you just use a switch-to-switch battery cable for the block/firewall connection?
i.e. something like this:
Old Jul 12, 2008 | 06:22 PM
az1966's Avatar
az1966
got my GROUND'S battery cable to engine block,,, and cylinder head to fireall (Braided cable )as was off the assembly line
Old Jul 13, 2008 | 06:58 AM
Norm Peterson's Avatar
Norm Peterson
Almost certainly done that way for reasons of production cost. Unless you"re going for an OE-style restoration, that"s one of the worst arrangements that you could choose, especially if you"re running aluminum heads. Reliability and long term electrical-related effects should count for more on any other kind of repair or rebuild.
I do realise that if a lot of these short cuts had not been taken by Ford that there might not be such a large Mustang community as exists today. But (except for OE-restored show cars) that"s no reason to not correct them as you go. Probably makes lessdifference in terms of overall car "character" than installing a Pertronix.
Norm
Old Jul 14, 2008 | 07:17 PM
Toddman0025
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
mrappe
Sep 26, 2015 10:16 AM
TfcCDR
Sep 14, 2015 12:08 PM
cbird1177711
Sep 3, 2015 08:43 PM
