How hot does the bay get?
Old Jul 11, 2008 | 11:54 PM
Nick.Simonds's Avatar
Nick.Simonds
Default How hot does the bay get?
About to start painting the engine bay. Found some Rustoleum that supposed to be very durable, like constuction equipment grade stuff. Although it says to not use on surfaces over 200 degrees
Old Jul 12, 2008 | 12:14 AM
Shawnb23's Avatar
Shawnb23
Default RE: How hot does the bay get?
I Used Rustoleum all over my floor pans ect.. Work's great. Add a hardener to it if you want it to last even longer. Can't say I've used it for high temp applications. Automotive paint isnt reall made to withstand heat and people paint their engine compartment's with it all the time.
Old Jul 12, 2008 | 01:07 AM
rst08tierney's Avatar
rst08tierney
Your engine bay will be fine with normal paint, IF you paint any pieces of the engine, this is where you need the high temp paint!
Old Jul 12, 2008 | 06:39 AM
coda618's Avatar
coda618
+1 High temp paint not needed for the bay itself.
Old Jul 12, 2008 | 09:47 AM
67BullittCoupe's Avatar
67BullittCoupe
i used rustoleum gloss finish on my 66 I6 and it came out perfect and you dont even need a primer.
im in the midst of repainting my 67 coupes engine bay. ill post pics soon. hopfully it will be done by tonight or tomorrow.
Old Jul 12, 2008 | 01:22 PM
Nick.Simonds
I will use the primer, its supposed to be a good rust protective. Plus im going with gloss, and want it to be pretty uniform. If I was going semi-gloss, I wouldnt go with the primer.
jwog666
Dec 27, 2021 08:09 PM
bradleyb
Nov 27, 2015 07:50 PM
jrrhd73must
Oct 2, 2015 09:17 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
