replacing wiring harness
Old Jul 12, 2008 | 12:22 PM
blue289's Avatar
blue289
Default replacing wiring harness
I would like to replace all of the wiring in my 67 convertible while i have it taken apart. Has anyone installed a Painless wiring harness? Does anyone have any suggestions on other replacements? The Painless kits are about the same price as the factory underdash harness in Mustangs Unlimited.
Old Jul 12, 2008 | 05:09 PM
zmetalmilitia's Avatar
zmetalmilitia
Default RE: replacing wiring harness
I just got my Painless kit from summit last week. I looked at, very nice with directions. Each terminated end is marked where it goes. I will be putting it in whenever I get my car back from paint. Hopefully next month. I also got the wire wrap stuff that will make nice and clean looking.
Old Jul 12, 2008 | 09:38 PM
bradleyb's Avatar
bradleyb
I got the Ron Francis unit - if you don't mind doing all the connectors yourself, the aftermarket can be ok. Also, the fuse box on my Ron Francis unit meant I had to cut the kick panel (not a big deal but it meant I had to remove the vent.....). Aftermarket stuff always means starting down a path of modifications, if you are good with that or have alot of other accessories, go aftermarket. If you want to plug and play, go with the factory harness.
Old Jul 12, 2008 | 09:58 PM
ky's Avatar
ky
America ftw
ORIGINAL: zmetalmilitia
does it come with all the connectors already crimped on? so its just a plug n go deal?
i need an underdash harness and tailight harness, everything else i replaced. (firewall forward)
Old Jul 12, 2008 | 11:28 PM
dugan's Avatar
dugan
i have heard nothing but good things about the painless harness
Old Jul 13, 2008 | 08:39 AM
mortman's Avatar
mortman
ORIGINAL: bradleyb
Not to go off topic but bradleyb, i have the Ron Francis as well, where did you mount the fuse panel? what kick panel? any picks would be great.
Old Jul 13, 2008 | 03:40 PM
zmetalmilitia
Yes the Painless harness is completely terminated. It is not a universal kit, it is the kit designed for the 67-68 mustangs. Comes with a gauge cluster too. I think mostwiring harnesses are the same. I mean its wire. It's not like it's different metal alloys, custom formed and heat treated, etc. If you are good with understanding electrical things, most harnesses should be relatively easy to install and understand. If you are not, most harnesses will kick your butt.
2007StangV6
Jan 28, 2016 06:09 PM
Doogie65
Sep 6, 2015 02:55 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
