thermactor cylinder plugs/ header problems
Old Jul 13, 2008 | 03:02 AM
greystallion66's Avatar
greystallion66
Default thermactor cylinder plugs/ header problems
Ok, so my 66 coupe has the stock heads with the thermactor ports in them. I called up mustangs plus and got the cylinder head plugs. They worked great with my exhaust manifolds, but I now have a pair of tri-y headers. The header flange will not clear the hex head of the thermactor cylinder plugs. I can't find anyone who sells the "sleeve thermactor" type. I was thinking of using a hack saw to cut off the hex head but do not know how I would reinstall them. Any ideas, or has anyone run into this issue before?
Old Jul 13, 2008 | 12:28 PM
greystallion66
Default RE: thermactor cylinder plugs/ header problems
bump
Old Jul 13, 2008 | 02:51 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I would say either grind the header flange until in clears the plugs or find a plug with the same thread that uses an allen wrench.
Old Jul 14, 2008 | 12:56 AM
greystallion66
does anyone know the bolt size for the thermactor plugs? I can't find the package the bolts came in anywhere. And if I grind the header flange until the plugs clear the header wouldn't I run the risk of an exhaust leak? I have no clue, never done this before.
Old Jul 14, 2008 | 02:51 PM
FasterCat's Avatar
FasterCat
http://store.summitracing.com/partde...0&autoview=sku
Old Jul 14, 2008 | 04:29 PM
greystallion66
Yea, I bought those. The plug is too large for my thermactor ports. Those plugs only fit newer 302's. Thanks for the help though.
Old Jul 16, 2008 | 09:49 PM
az1966's Avatar
az1966
grind something !!!!!! i have a 66 6 popper and the holes are recessed,,,question how do headers mess up a deal like this when the plug holes are so deep in the intake mainfold?
2007StangV6
Jan 28, 2016 06:09 PM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
bconboy
Sep 21, 2015 12:52 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Luke9222
Sep 4, 2015 06:46 AM
