help:fuelpump issues
Old Jul 15, 2008 | 07:47 PM
Gun Jam's Avatar
Gun Jam
Default RE: help:fuelpump issues
I see
happy hunting.
-Gun
Old Jul 15, 2008 | 07:50 PM
blackfoot's Avatar
blackfoot
well with some quick research, i found a little tag on the fuel pump. 12833.. i looked it up on keystone and it turned out to be a part number for a holley fuel pump.. but no info, so i went on the holley website and looked up the part number i learned its a 80gph pump at 7.5psi of pressure
should i go ahead and get the same pump, or would you guys recomend me to go bigger?
Old Jul 15, 2008 | 08:09 PM
Gun Jam's Avatar
Gun Jam
80 gph would probably work okay for you but 7.5 PSI will probably unseat inlet needles and thus rapidly flood the engine. You would have to run a regulator at 7.5psi which cost more and tend to fail from what I have seen.
-Gun
Old Jul 15, 2008 | 08:26 PM
blackfoot's Avatar
blackfoot
well ive gone 5 years on the same pump... i think ill order it up, and get a bigger pump when i get the bigger carb..
thanks for the help and input!
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
