starting problems
Old May 7, 2005 | 12:21 AM
BillyBobJoe's Avatar
BillyBobJoe
Default starting problems
Well, I jsut got myself my first classic mustang. 1969 model with a 351W engine. I cant get the engine to start though. It is cranking over but thats all. MY first thought was out of gas, but nope. So what I did was I disconnected the gas hose that goes from the pump to the carberator and put it in a bag, when I tried to start it, the bag stayed dry, so I assume the pump is bad. Now before I go waste my time with a new one, does anyone have any tips? or think differently?
P.S. I also got several random hoses and wires that come from one thing but dont go to another...very strange. Ill get some pics and make a new post for that though. Dont worry, this should be why it wont start, the shipping company of the car said it was running before they got it on the trailor, then it either ran out of gas, or like I said, the pump died.
Old May 7, 2005 | 12:36 AM
Markstang1969's Avatar
Markstang1969
Default RE: starting problems
ORIGINAL: BillyBobJoe
Welcome to the site. You say it "may be out of gas". Did you check the hose from the tank TO the pump?
Old May 7, 2005 | 12:53 AM
BillyBobJoe
ya, i checked the hose and it seems good. I even pulled it off from where it connects to the pump and gas came out. The hose from the pump to carb. looks good but may be clogged. The outside is visually fine.
Old May 7, 2005 | 01:20 AM
Markstang1969
Sounds like pump or line, yes. Have you primed the carb to see if the car has ignition once it gets fuel?
Old May 7, 2005 | 01:26 AM
BillyBobJoe
no, i didnt prime it, im a bit of a noob when it comes to engines, can you tell me how to do this?
Old May 7, 2005 | 02:01 AM
67coupe's Avatar
67coupe
Take the air cleaner off. Pour in a small splash of gas. Reinstall the air cleaner in case you have a backfire. Then try to start it. If it fires up and quits after the small amount of gas you put in is gone then you know fuel or lack of is the problem.
Old May 7, 2005 | 02:14 AM
BillyBobJoe
poored in the gas and stil not starting. might not have put enough in but i think i did
Old May 7, 2005 | 07:51 AM
Soaring's Avatar
Soaring
I ♥ Acer
Most likely the carb is dry, so pour in about a cup of gas, then pump the foot feet two or three times, then try to start it. If you aren't getting gas out of the pump, then probably the pump has gone south. Also, make sure you have ignition. Pop the distibutor cap, and turn the engine so the points are completely closed. Turn the key on, then use a screwdriver to mechanically open and close the points. If you get a spark, you have ignition. Get back with us if none of this works.
Old May 7, 2005 | 07:50 PM
Markstang1969
Not sure if you are familiar with old carbureted cars, but you sometimes have to press the accelerator as you ar starting it (unlike fuel injected cars)
Old May 7, 2005 | 10:02 PM
BillyBobJoe
ya, i tried to press the accelerator a few times but nothign happened. I'm gonna give Soaring's idea a try when i got home tmw. I'll tell you all how it works out.
