No start
Old Jul 17, 2008 | 02:15 PM
robert912004's Avatar
robert912004
Default No start
Ihave a 65 coupe with a 302, C4and it wont start. I have jumped the relay to see if it would crank over and it does, but when i try it with the key it wont start.I have the trans. in park and still nothing.I just recently took the engine and transmission out to fix the trans. and while i took that out i also took thegauge cluster. Does the gauge cluster have anything to do with the ignition? There are some wires coming from the trans and i dont know what they are, if anyone could tell me it would be helpful.
Thanks
Robert
Old Jul 17, 2008 | 02:40 PM
Daze's Avatar
Daze
Default RE: No start
double check the neutral safety switch connections at the trans. If that connection is not intact you will have the exact problems you described
Old Jul 17, 2008 | 04:44 PM
robert912004
well there is four wires coming form the trans. and i think that it is the neutral safety switch. I dont know know which one goes to which plug.
Old Jul 18, 2008 | 10:24 AM
boogerschnot's Avatar
boogerschnot
ohh,,, Do you have a Hanes manual? Mine is at home right now.. Someone might be able to help you out with a wiring diagram. Maybe check the FAQ section.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
