What this thing?
Old May 8, 2005 | 11:48 AM
BillyBobJoe's Avatar
BillyBobJoe
Default RE: What this thing?
ok, now, I alo have that on my 351W (1969). My vacum hose goes from the EGR to my filter assembly. If that's bad, whre should it be going?
Old May 8, 2005 | 12:40 PM
TBIAgent69's Avatar
TBIAgent69
Umm... I'm not too sure where it hooks up on this particular motor, but I believe it needs to be hooked up to a vacuum source that is sucking while cruising?
Old May 8, 2005 | 02:11 PM
73Cleveland's Avatar
73Cleveland
The vacume for the EGR runs off of carb vacume. It may run off of a T'ee somewhere but it should trace back to carb vacume.
If you hook it up to manifold vacume, it will be open at idle, not good!
If you are not replacing anything on that engine, just block off the vacume line at it's source or pull the line from the EGR and put a plug in the hose.
Old May 8, 2005 | 02:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 73Cleveland
I got a giggle out of "put a plug in the hose." I had an old Chevy one time that I just used a metal screw just bigger than the hose, and screwed it in there. Talking about southern engineering. Anyway, the best way to plug a vacuum line is to buy a 10 cent nipple from a parts place, take off the hose, and slip the nipple over the vacuum tit.
Old May 8, 2005 | 05:39 PM
TBIAgent69's Avatar
TBIAgent69
ORIGINAL: Soaring
In fits of despairaion I have been known to remove a bolt/screw from the body to jam in there, fill the hose with RTV and let it dry, or even remove a plug from somewhere else and just connect vacuum to vacuum Then there's my personal favorite, kinking the hose and tying it off with a piece of spare wire or electrical tape.
Old May 8, 2005 | 07:08 PM
Soaring's Avatar
Soaring
I ♥ Acer
Then you must be a Southern boy like me.
Old May 8, 2005 | 09:57 PM
73Cleveland
Sometimes ya gotta do what ya gotta do!
KingRando
Oct 2, 2015 08:06 AM
RCS02v6
Sep 29, 2015 01:46 PM
GLOCKer
Sep 28, 2015 07:36 AM
treesloth
Sep 28, 2015 07:03 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
