Suspension Installed......Pics
Old Jul 18, 2008 | 06:31 PM
juansp67's Avatar
juansp67
Default Suspension Installed......Pics
Finally got Some time to install my new suspension check it out.
The Shelby Drop looks like it came out good wont know until i drive it
What do you think
Old Jul 18, 2008 | 06:46 PM
Gun Jam's Avatar
Gun Jam
Default RE: Suspension Installed......Pics
looks good
who made that kit or are those parts you picked out?
Some higher rate springs might be in order, what about shocks?
-Gun
Old Jul 18, 2008 | 07:46 PM
ky's Avatar
ky
America ftw
those look like 620 springs.
and i see the shock towers are new. we replaced one in my dads 66. it turned out perfect. all the measurments we got exactly the same.
Old Jul 19, 2008 | 05:11 AM
juansp67's Avatar
juansp67
ORIGINAL: Gun Jam
looks good
-Gun
Actually i bought my upper and lower C/A from California Mustang they came black coated they were cheaper than any other manufacturer that i looked for and i wire brushed and painted my sway bar and the other two located below the radiator crossmember.
AS for the springs i bought the Grab-A-Track rated at 620/lbs and they say they lower your about an 1" or so, and if they dont i did the shelby drop and cut both springs about 1/4' not a lot just enough im running 16" rim on the front so i hope they fit real snugged
Old Jul 19, 2008 | 05:18 AM
juansp67's Avatar
juansp67
ORIGINAL: true66gt
yes they are the 620/lb springs.
I did not install new shock towers these are the originals what i did was since i took off the upper c/a i wire brushed the shock towers real goood to bear metal and decided to give it a taste of my own something different it looks good[:-]
Old Jul 19, 2008 | 11:31 AM
SalikDDD's Avatar
SalikDDD
i had those same springs, i removed em for the proper drop and i went with 1966 289 springs in the front for my 67. the 620's from them are stiff as hell and didn't lower one bit :/ then when i called to ask why they are so stiff and i had no lowering they blamed it on me.
Old Jul 19, 2008 | 03:08 PM
baddog671's Avatar
baddog671
I hope you have some smooth roads
Old Jul 19, 2008 | 03:46 PM
Gun Jam's Avatar
Gun Jam
Im running the street bandit handeling kit I got from NPD. it uses 650 rate springs as I recall and KYB shocks.
It lowered the front about 2" and the ride is not too bad. I actually get comments about how smooth the car is...But yes its stiff and yeah you do feel a lot more bumps than with the stock suspension. What an improvement in handeling though she goes where I point her now and is much more fun to drive... totally wort it!
-Gun
Old Jul 19, 2008 | 04:02 PM
juansp67's Avatar
juansp67
yea im not looking for a smooth ride it really dont matter to me as long as i get better handeling is what matters.
i have an 99 SI ans its dropped to da floor thats what i call a bumpy ride but whoa i have total controlon those curves
Old Jul 19, 2008 | 05:55 PM
ky's Avatar
ky
America ftw
ORIGINAL: SalikDDD
cause they require a while for them to settle down. like a few months of driving. and they also require cutting if you want them to be lowered.
to get the car lowered immediately you can either:
1. cut the springs and leave control arms in stock spot.
2. leave springs uncut, and shelby drop.
but i cut my springs and i plan on shelby dropping my CAs so we'll see if its too low. but im getting rid of a lot of weight in my engine bay so i should be fine. like battery relocation, aluminum heads and intake, no more PS, etc.
