Battery cable terminal?
Old Jul 20, 2008 | 08:36 PM
baddog671's Avatar
baddog671
Default Battery cable terminal?
I got my thicker battery cable for my relocation project, wrapped it up with tape, and went to the store to get terminals for it. Now, I got brass terminals for the battery posts (better than lead/steel ones, right?), but what is the correct name for the terminals at the other end? Like, where the battery cable connects to the solenoid and I suppose you could use the same type for the ground cable? The store had "cable lugs" which I guess is what I'm talking about, but they were only 3/8" opening and I'm using a 1guage wire....
Nic
Old Jul 20, 2008 | 08:55 PM
Scott H.'s Avatar
Scott H.
Default RE: Battery cable terminal?
Old Jul 20, 2008 | 09:02 PM
baddog671's Avatar
baddog671
Ok, thanks! You think they would just make one that bolts down like thebattery post connectors...
Old Jul 20, 2008 | 09:06 PM
JamesW's Avatar
JamesW
You may also wish to consider soldering the connection after you have staked it. Basically you put the cable in a holding fixture (Vise, clamp, etc..) then take a propane torch and heat up the lug/wire end. When hot enough, the solder will wick up inside the connection making it solid. Remember to use a flux before staking the cable in the lug.
You may also want to use some heat shrink over the end to keep it from arching on anything.
Old Jul 20, 2008 | 10:40 PM
Starfury's Avatar
Starfury
psssst, Napa sells them too:P If you're nice, they may even build you a cable. It may be expensive, but you won't have to buy the tools yourself...
Old Jul 20, 2008 | 11:04 PM
Scott H.'s Avatar
Scott H.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
logan409
Sep 26, 2015 07:43 PM
