subframe connectors
Old Jul 22, 2008 | 10:29 AM
webjepn21's Avatar
webjepn21
Default RE: subframe connectors
Hello, though it is most likelyto late to change your mind now, Go to photobucket, type in webjepn21 to find my albumand look at the TCP connectorsI used ona GT-350R clone I am building.TCP also offers a lower cage with driveshaft loopthat bolts in between rails to tie everything togather. The front suspension is also TCP, as is F&R shocks,Rack&Pinion, and upper tower braces. Very pricy but car handles like a new vette. Almost finished,Lots of little details left. Tony.
Old Jul 22, 2008 | 04:08 PM
69FB's Avatar
69FB
I looked at the tinmanas well. Very nice product but I'm planning on going with the TCP setup since I'm going to use their R&P and Front Coilover as well.
Let me know what you think of those tinmans.
They were my second choice.
Old Jul 22, 2008 | 09:49 PM
Angliagasser's Avatar
Angliagasser
Here is what I am using on my daughters 66 Mustang, that I am putting a well over 300hp SVO 2.3 turbo motor in. They are from Heidt's. The bottom one is pictures of the whole build so far and a few of my other cars.
http://i259.photobucket.com/albums/h...CN04190268.jpg
http://i259.photobucket.com/albums/h...CN04170266.jpg
http://i259.photobucket.com/albums/h...CN04200269.jpg
http://s259.photobucket.com/albums/h...e_top_view_all
Old Jul 22, 2008 | 10:00 PM
Daze's Avatar
Daze
If you can weld, why don't you make your own for about $30.00 I have plans and a how-to on the topic
DazeCars subframe connectors
This are very similar to the tinman ones in form and function
Old Jul 23, 2008 | 11:59 PM
bradleyb's Avatar
bradleyb
I did the stage 1 & 2 kit from TCP - it was pricey, maybe 360ish at mustang depot but it does handle pretty tight. It does make the car bounce a bit being so rigid but I like it
Old Jul 24, 2008 | 01:10 AM
Adrenolin's Avatar
Adrenolin
ORIGINAL: bradleyb
Precisely why I didn't go that route. Makes the car feel like a go-kart. Regular sub frame connectors stiffen up the car enough for daily and enjoyable driving. Great if your looking for a performance setup but not what most people need. To each's own though
Old Jul 24, 2008 | 09:25 AM
urban_cowboy's Avatar
urban_cowboy
Damn forum gremlins! I lost my reply.
I put on a set of TCP weld on style subframe connectors and cross brace. It is one of the best mods I have found yet! It along with my CE Slide-a-links really made a nice rear end! When welding them in, I have two pieces of advice. Try to clean as much of the area you are welding to as possible. The undercoat stuff is nasty to weld thru. Second, remove your carpet! I toasted the passenger side and dang near burnt ol' whisky up. I was replacing the carpet anyway, so no big deal but remove for saftey any Dynomat, carpet, or padding where you are welding.
jwog666
Dec 27, 2021 08:09 PM
guitarman376
Oct 11, 2015 01:47 AM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
Sep 16, 2015 07:53 PM
TfcCDR
Sep 14, 2015 12:08 PM
